×JIRA works fine until I start the other NIC that is on a different network. JIRA tries to use eth1 instead of eth0, which it can use just fine. How do I tell JIRA to use the correct network interface. This is JIRA standalone 6.2.5 on CentOS 6.1
You should be able to modify the "Connector" in server.xml
to bind to a specific address.
<Service name="Catalina"> <Connector port="8080" address="10.0.0.123" <!-- Use desired bind address --> maxThreads="150" minSpareThreads="25" connectionTimeout="20000"
Disclaimer: I haven't verified this first hand.
