How to configure velocity chart to show more than 7 sprints
yusuf jamal
April 24, 2018
Hi
I want to see more than seven sprints in velocity chart, please let me know how to configure it.
Manon Soubies-Camy
Hello @yusuf jamal,
You can't configure this in Jira. You can vote for the feature request here: JSWSERVER-6034.
You could alternatively use an app like eazyBI and build your own velocity chart (see example here).
Hope this helps,
- Manon
yusuf jamal
April 24, 2018
Thanks Manon for quick reply..will check easy BI
Meena Menon
That's too bad, would think it is table stakes.
Like # people like this
Andrew Mallonee
Agree, for a tool that revolves around this sort of info I don't understand why it is limited in it's reporting ability (without additional apps of course!) You could do this in server if I recall so they basically have/can do this they just chose to remove it 9not carry it over) for some reason.
Danut M [StonikByte]
A possible option would be to use the Great Gadgets add-on by StonikByte.
It offers a Velocity Chart gadget that allows you to specify the number of sprints to be displayed.
Please note that I’m one of the folks behind StonikByte, there may be other solutions out there.
