Is there any way to configure what fields shown in the Details section of the task in any view mode (Edit, Create, View) ?
Hello @Karmandroid Singularity
From your backlog view, top right, click on Board Drop down--> "Configure" .. Then in the new screen, in left hand menu, select "Issue Detail View", from there you can add/remove /customize.
see the 2 screenshots below. hope it helps, Thanks!
Perfect!
This is what I am looking for, I wonder how can I missed such option on Board Configuration :)
Thank you
