How to connect servlet to jsp file in jira
Bruno Fidrmuc June 4, 2018 edited
I have a working jira plugin, with a servlet. But at this point my servlet only prints out "Hello world" as shown on a picture below. It is linked to a simple .vm file.Now I would like to link my servlet to a .jsp file, but I can't find a proper tutorial for that or a good answer that fix my problem. When I try to connect servlet with jsp I get 500 error.
Alexey Matveev
June 4, 2018
How did you develop the servlet? Why do you want to connect it to JSP file?
HI,
I have developed servlet following this tutorial https://developer.atlassian.com/server/jira/platform/creating-a-jira-issue-crud-servlet-and-issue-search/ , I want to connect (link) it to jsp file because I have web application that I have to integrate as jira plugin
Alexey Matveev
June 4, 2018
You should choose first the place in Jira UI, where you would like to connect your servlet. Then you can create a web item, which would call your servlet. Here is a tutorial:
https://developer.atlassian.com/server/jira/platform/adding-menu-items-to-jira/
I have no problem with location, first one I created was in new tab, and I had a button (web-item) which called servlet. Only problem that I have is JSP I don't know how to call JSP from servlet I used
RequestDispatcher rd = getServletContext().getRequestDispatcher("locatio");
rd.forward(request, response);
RequestDispatcher rd = request.getRequestDispatcher("/start.jsp");
 request.getRequestDispatcher(request.getServletContext().getContextPath() + "/start.jsp").forward(request, response);
but none of the above worked for me. Is there a specific folder where JSP files have to be?
Alexey Matveev
June 4, 2018
Why would you need a jsp? You can return a vm or soy templates for user interface.
Because web app that I have uses jsp files so if I don't have to change them I wouldn't, but if there is no other option I will have to change them.
Alexey Matveev
June 4, 2018
I put jsp pages in the webapp folder. Have a look inside the folder and you will see other jsp page there. Then you can call the jsp by base_url/yourjsp.jsp
Like • Jaroslav Pavlicek likes this
