Dear ALL,
being struggling to code an Jira automation rule which triggers when a sub-task is created and as action it should copy a specific field value (of the sub-task) to the equivalent field of its Epic (so, being the grand-parent of the sub-task).
Could you please help me out with the syntax?
I have created a smart variable called EpicKey as {{issue.parent.epiclink}} but the automation returns nothing.
I use Jira Data Center version 9.12.16.
Thanks in advance, Vincenzo.
Thanks Ariel.
I have tried that out and that gives the sub-task parent but I'm after the Epic of the sub-task, so the grand-parent of the sub-task.
Do you know whch is the syntax in this case.
Thanks, Vincenzo.
Hi Ariel,
still null but you gave me an idea.
It works with:
{{issue.parent.epic}}
Thanks for your time, Vincenzo.
happy to help, please accept the answer.
