×Greeting! I'm trying to copy assignee from parent link ("is Parent of") to child("is Child of") by SIL listener
Help me pls to fix this script.
My script looks like this:
if(project == "AISRITS" && issueType == "Requirement"){
JIssueLink[] jIssueLinks = getIssueLinksDetail(key);
string assignee;
string papa = linkedIssues(key, "Parent");
string nepapa = linkedIssues(key, "Child");
for(JIssueLink jIssueLink in jIssueLinks){
if(jIssueLink.issue.issueType == "Sub-Requirement" &&
jIssueLink.description == "is Child of"{
//jIssueLink.description == "is Parent of"{
nepapa.assignee = papa.assignee;
Hi!
Does your script throw an error or does it do something different then you want.
Regardless, it still contains a syntax error. You are missing a ) after "is Child of". So to run the code should be:
if (project == "AISRITS" && issueType == "Requirement") {
string assignee;
for (JIssueLink jIssueLink in jIssueLinks) {
if (jIssueLink.issue.issueType == "Sub-Requirement" &&
jIssueLink.description == "is Child of") {
Hope this helps!
Jeroen
