How to copy comments form a ticket in Project X to a related ticket in project Y
Neil Shah February 20, 2019
I have a ticket in project x and i am trying to copy the comments over to a related ticket in project y. How can i do this.
I have provided a link below which shows how to do this but it does not seem to work after implementing.
https://innovalog.atlassian.net/wiki/spaces/JMWEC/pages/438763786/Copy+comments+to+linked+issues
Please advise.
Neil
Angélica Luz
February 21, 2019
Hi Neil,
The best option, in this case, is to use the add-on Automation for Jira (there is a free version Automation Lite for Jira Cloud).
You can add the conditions below, so when an issue is commented, the comment will be copied to the linked issue:
Please, give it a try and let us know how it goes.
Angélica
Petter Gonçalves
February 21, 2019
Hello Neil,
Natively on JIRA, you can use CSV export/import functionality to export the comments from an issue and import into another.
Besides that, there are some plugins that you can use to achieve this goal. Here are some suggestions:
1 - ScriptRunner plugin - using a workflow transition to trigger the script:
Copy Comment to Linked Issue based on workflow transition
2 - Using Automation for JIRA - Also with a workflow condition:
How to copy comments from Linked Issues
3 - Using JMWE - as you suggested.
About the option you have tried, can you please let us know how you have filled the options in the post function? Also, have you saved your draft workflow once you added the Post function?
We will be witing for your answer.
Neil Shah February 22, 2019
Hi Petterson,
Thanks for getting back to me. Please see attached screenshot of how i filled in the fields using JMWE comments.png
Not sure whether in the destination, i need to put relates to
Neil
David Fischer
Hi Neill,
I recommend that you raise a support request at https://innovalog.atlassian.net/servicedesk/customer/portal/10
This way, we'll be able to investigate why the post-function is not working.
Regards
David
