How to copy comments from cloned issue as soon as someone comments?
Surbhi Soni
So, I have created a Project-A and  it creates a cloned issue in Project-B  on a transition using post function.
• Now, I want that if anyone comments on cloned issue in Project-B, it should be copied on Project-A issue.
• Comments should be copied  from Project-B to Project-A, not only on transition but  as soon as it is commented.
Is this possible?
Environment: JIRA Cloud.
Surbhi
Angélica Luz
November 23, 2021
Hello everyone,
It’s been a while since this question was posted and at that time Automation for Jira was an add-on and today it’s part of Jira.
In my previous answer from 2019, the smart value was {{issue.comments}} but it indeed changed and the correct one now is {{comment.body}}.
I tested the same automation here today to copy comments from the linked issues and it works, it’s just necessary to change the smart value to {{comment.body}}.
Screen Shot 2021-11-23 at 13.14.55.png Screen Shot 2021-11-23 at 13.13.32.png Screen Shot 2021-11-23 at 13.18.30.png
Hope this helps!
Angélica
Emanuel Pinkwart
thanks a lot! that really helped!
Like Angélica Luz likes this
Raman May 25, 2022 edited
Hi @Angélica Luz ,
Thank you for this answer!! That really helped!!.
Is there an option to sync the comments which are Edited??
I edited a comment in Parent issue. But the changes not getting reflected in the cloned ticket.
Please let me know if we have any options to achieve it.
Thanks in Advance!!
Rodrigo Meurer May 25, 2022
Hi Angelica. I did the exact same thing, but it's not working. In the automation audit log, it just says "no related issues could be found"
Than I even inserted a re-fetch issue action, but it didn't change the result. An I have a cloned issue as you can see in the below attached image.
I'm creating the automation in a Jira Software project, and the issue I'm making the comment is cloned from a Jira Service Management project. But searching in the community it looks like this shouldn't be a problem. I also found your comment in this question https://community.atlassian.com/t5/Jira-Service-Management/Clone-an-issue-from-service-management-to-software-and-copy/qaq-p/1651768
Rodrigo Meurer May 26, 2022
I have found the problem why it didn't work for me. The automation must be Global or Multiproject.
David Arévalo April 26, 2024
Good morning @Angélica Luz ,
I know it's been a while since your response, but is there a way to just pass on public comments? Because all comments are moved this way, including internal notes, is it possible to only transfer those comments that are public?
Thank you and greetings.
4 votes
Riddhi Shah
June 30, 2020 edited
Hello @Surbhi Soni
I'm Riddhi from the Exalate team, Exalate is made for the use case you described. As it allows syncing information bi- and uni-directionally between multiple Jira instances. Or separate projects in your local Jira.
It's mega flexible, you can sync all types of information, including comments, attachments, and custom fields. You can control what to sync and whatnot, and much more ....
It can also cater to situations of dealing in a private to public sync, You can find out more about it here.
undefined
By the way, It might also be useful to set up a live video-discussion to demonstrate how Exalate would get set up for your use case
Would that be valuable to you? You can book a suitable slot here.
Riddhi
Angélica Luz
June 4, 2019 edited
Note: This answer is outdated. The smart value changed from {{issue.comments}} to {{comment.body}}. Please, check the new answer posted on November 23 for more details.
Hi Surbhi,
Currently, to copy a comment from a linked issue to the main issue, it's necessary to use an add-on like Automation for Jira. There is a free version where you can test everything that you need.
Once you install, you can create this automation:
Please, give it a try and let us know how it goes.
Angélica
Surbhi Soni
Hi @Angélica Luz ,
Thanks for the response.
We do have JMWE plugin for JIRA.Is there any way this can be achieved using Nunjucks Templates/filters?
Surbhi
Tushar.Kamble
Hi @Angélica Luz ,
Can we copy comments while cloning the Jira issue in cloud?
~Tushar
Amol Tajave
March 13, 2020
I am also facing similar issue on jira cloud. Did you get any fix for it?
shrikant maheshwari May 4, 2021
I tried using Automation for JIRA but it does not post comments on main issues from link issues neither vice -versa.
Emanuel Pinkwart
I tried the same using the automation rule as outlined above with same result, no success.
It looks like the cloned issue gets updated, but it gets only updated with its own comments, not with the comments from the triggering issue. Is there any fix for that? What would be the right code be that needs to go into the the automation rule ( {{issue.comments}} seems to be the wrong one. @Angélica Luz
Jesse Kona
I had luck with {{triggerIssue.comment.body}}
This added all of the comments concatenated together.
Like Tim Johnson likes this
Ulrika Eriksson
I think this can be done by add-on "Elements copy & sync" to, but only for server and Datacenter.
https://marketplace.atlassian.com/apps/1211111/elements-copy-sync-formerly-exocet?hosting=server&tab=overview
Julie d_Antin _Elements_
Thanks for the recommendation @Ulrika Eriksson
@Tushar.Kamble @Amol Tajave Elements is working on a Cloud version of Copy & Sync that will allow you to copy comments (in addition to fields and attachments).
Would you be interested in getting news about the Cloud version of Elements Copy & Sync? I can add you to our communication list for the forthcoming app.
Like Amol Tajave likes this
Radhika Vijji _Innovalog_
June 6, 2019
Hi Surbhi,
Unfortunately no! With JMWE you can automate an action on the trigger of a transition only. You could use listeners provided by any other add-on to accomplish it.
Radhika
Read the story
