You can create a Script Runner Scripted Field.
The script for the field will look like:
import com.atlassian.jira.component.ComponentAccessor a = ComponentAccessor.getIssueLinkManager().getLinkCollection(issue, issue.reporter).getAllIssues().size() a.toString()
More info on scripted fields:
https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+Fields
Which part did not work ?
Is the field shown with wrong value or it is not there at all ?
Hi Boris, I needed to count specific type of linked issues. Ex:- issue has 2 type of linked issues, 2 linked as blocks and 2 linked as clone. How can i get these separately. Current answer is 4, but i need 2
Hi Thuy Mai,
Try Database Value plugin and select
count(*)
from
issuelink
where
SOURCE=(
select
id
from
jiraissue
where
pkey=
'${jira.issue.key}'
or
https://answers.atlassian.com/questions/215718/scripted-field-to-return-number-of-cloned-issues-not-workingscripted field will help you most rather than DB value plugin.
I think its little bit closer to your requirement.
Cheers
Hi - does anyone have a script sample for the cloud version? Thanks!
Worked with a slight modification of Boris script:
def CountLink = ComponentAccessor.getIssueLinkManager().getLinkCollection(issue, issue.reporter).getAllIssues().size()
CountLink.toString()
Amazing, thank you :)
Hi @Philippe Puy ,
I faced a problem for this script. Do you know how to count the number of linked issues base on linked issues type? Thank you very much!
Hi Thuy Mai,
count(*)
from
issuelink.
Cheers
Hi Thuy Mai,
count(*)
from
issuelink.
Cheers
Register now
