Hi Everyone can any one help me In this ... How to create a branch automatically in Bitbucket when an issue in jira is transitioned from one status to another status . Can any one please help me on this thanks in advance
Yes, you certainly can. You would need ScriptRunner in your Jira instance.
There are two ways to do it. Basically you make a POST call using the following Rest API to create a branch in a workflow post function from Jira to BitBucket:
1. Setup the app links as mentioned in this documentation.
2. Following snippet works as I have tested:
import com.atlassian.applinks.api.ApplicationLinkResponseHandler
import com.atlassian.applinks.api.ApplicationLinkService
import com.atlassian.applinks.api.application.bitbucket.BitbucketApplicationType
import com.atlassian.sal.api.component.ComponentLocator
import groovy.json.JsonSlurper
import com.atlassian.sal.api.net.Request
import com.atlassian.sal.api.net.Response
import com.atlassian.sal.api.net.ResponseException
import com.atlassian.sal.api.net.ResponseHandler
import groovy.json.JsonBuilder
def appLinkService = ComponentLocator.getComponent(ApplicationLinkService)
def appLink = appLinkService.getPrimaryApplicationLink(BitbucketApplicationType)
def applicationLinkRequestFactory = appLink.createAuthenticatedRequestFactory()
Map body = [
startPoint: "refs/heads/master",
def request = applicationLinkRequestFactory
.createRequest(Request.MethodType.POST, "/rest/branch-utils/1.0/projects/JP/repos/just-repository/branches")
.addHeader("Content-Type", "application/json")
.setRequestBody(new JsonBuilder(body).toString())
.execute(new ApplicationLinkResponseHandler<Map>() {
@Override
Map credentialsRequired(Response response) throws ResponseException {
return null
@Override
Map handle(Response response) throws ResponseException {
new JsonSlurper().parseText(response.getResponseBodyAsString()) as Map
You can use this sample script from our library as reference to make the same POST call:
import groovy.json.JsonOutput
import groovyx.net.http.ContentType
import groovyx.net.http.HttpResponseDecorator
import groovyx.net.http.RESTClient
final externalUrl = "http://<BitBucket_Base_URL>/"
def body = [
def postResponse = post(externalUrl, "/rest/branch-utils/1.0/projects/JP/repos/just-repository/branches", new JsonBuilder(body).toString())
def post(def hostUrl, def endpointAndQuery, def bodyJson) {
def client = new RESTClient(hostUrl)
client.setHeaders([
'Accept' : ContentType.JSON,
'Authorization': "Basic ${'xxxx:xxxxxxxx'.bytes.encodeBase64()}"
client.handler.success = { HttpResponseDecorator response, json ->
json
client.handler.failure = { HttpResponseDecorator response ->
// Failure can be handled here
log.error response.entity.content.text
client.post(
path: endpointAndQuery,
contentType: ContentType.JSON,
body: bodyJson
Please note that this will hardcode a username and password in your script.
Deleting a branch is just similar using a DELETE call on the same REST API.
I hope this helps!
