How to create a button checkbox "create another request" in Jira Service Desk Cloud ?
Guillaume Marcenac April 28, 2017
Hello Atlassian Community,
I am using Jira Service Desk Cloud solution for my company and I
am wondering if it is possible to have a special field like a checkbox at the end of the creation of the request called "create another request" in a JIRA Service Desk. This field will works exactly the same as "create another issue" for JIRA Software. Please, do you know if it is possible ?
I search a way to do that with the features proposed by Jira service desk without find any simple solution.
Nic Brough -Adaptavist-
April 28, 2017
That's going to need a code change or add-on to adjust the interface, which you can't do in Cloud.
Thanks, I just wanted to be sure there is no others options :).
LECOQUIERRE Hugues
September 13, 2017
Hi JIRA Team,
5 months later, is this still not doable?
We have two different workflow, one for managing functionnal requests and one for test defects, and I need at some point to create defects that relate to a functional request into the test defects. still not doable ?
hugues
