×I need to create jira addon using active object.
Kindly have a look at the tutorial below
https://developer.atlassian.com/server/framework/atlassian-sdk/getting-started-with-active-objects/
i asked to create jira plugin using this URL
(localhost:2990/jira)
not refapp
The refapp docs are valid for all Atlassian applications that support add-ons, the refapp is simplified to show you how common components work. You can use the same techniques in the refapp to work within Jira.
