How to create bugs automatically in JIRA when a testcase fails in Jenkins
Aishwarya Srinivasan April 7, 2022
I am currently using testng for automation
and use jenkins CI to execute functional testcases
i want to know the process of easily filing a bug when we have a failure encountered while testing
2 accepted
verraf
The simplest way is to use the issue creation rest api with which you can control the project in which to create the bug, the fields to populate and possibly the default assignee.
Aishwarya Srinivasan April 11, 2022
thank you- any reference documentation for the same
Mehmet Şirin Usanmaz
April 7, 2022
You can do this with a jenkins plugin by following the document below.
https://plugins.jenkins.io/JiraTestResultReporter/
Best Regards,
Mehmet Sirin Usanmaz
thank you
Aishwarya Srinivasan April 12, 2022
@Mehmet Şirin Usanmaz
can i set this up in jenkins for functional testing failures (UI side)
i thought this will help for build failure
does this also help in filing bugs for functional testcases
