How to create custom field type programmatically in jira?
Vedant Kulkarni
How to create custom field type which automatically gets the logged in user by using jira java API?
MoroSystems Support
September 15, 2017
there is a tutorial with new custom field type creation:
https://developer.atlassian.com/jiradev/jira-platform/guides/fields/tutorial-creating-a-custom-field-type
The value you want to display can be got using
ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
 Or you can use Script Runner plugin and its Scripted field which would be easier than to create a new custom field type
