Requirement:
Create a sub-task for each creation of Bug issue.
Means, if we create a bug issue then a postfunction should create a sub-task in it.
Hi ,
You can use the Create on transition plugin . Its provides a postfunction for creating a subtask . You can add this postfunction on the Create transtion.
Exactly the same requirement is found in mentioned plugin.
But it is providing the extra functionalites also
I want only the specified requirement.How to do customization?
What extra functionalities is provided ? I dont think you will need customization , you dont use what you dont want :)
Why is that needed for creating sub-tasks?
Link type ids is what you get by going to http://yourserver/secure/admin/ViewLinkTypes.jspa
what is issueLinkTypeId and how can we get it?
Yes you're right?
For the given link I am getting
browser error
The link was to the same page.
https://confluence.atlassian.com/display/JIRA/Configuring+Issue+Linking
Thanks Renjith, I got basic Idea about it
In the method call
createIssueLink(parentIssue.getId(), subIssueObject.getId(),xxxxx , user);
xxxx is issueTypeLinkId is a long type and how to get the type which is present in JIRA.
I guess this should been posted as a new question. I thought the orginal question here was about creating a sub-task.
Again Bharadwaj, new question. Before that try a google search :)
If I need to develop, the automatic creation of subtask issue when I create a Bug type issue.
How to approach?
