Hello All,
My question is, How to create multiple isses in multiple projects when one custom field gets updated?
Like for example, we have field called "Versions Affected" which is drop down field having V1, V2, V3..... If the user selects V1 from the drop down, a new ticket has to be created in Project called "Release 1", like wise V2 for "Release 2", V3 for "Release 3".....
Thanks in advance,
Sahish.
Hi @Sahish --
As long as your Rule is scoped to be global (all projects) or to the multiple projects where you will need to create issues, then you should be able to:
