I want to create # of sub-tasks using ScriptRunner query.
E.g. we got 150 Hrs of Estimation and want to create 5 sub-tasks of 30 Hrs estimation each with same title for each sub-task getting created.
This will solve a big administrative time as right now, we have to create this manually.
The user will input following in query
Parent task ID
# of sub-tasks needed
Estimation Hrs for each sub-task (will be same)
type of sub-tasks
Basis on above inputs, query would create the sub-tasks.
The basic "create sub-task" as a one-off can be taken from https://library.adaptavist.com/entity/create-a-sub-task-and-link-to-parent-issue-in-jira - you'll want to embed the "create" in the a loop read from the "# of sub-tasks needed"
For the estimate, from memory, you can use setOriginalEstimate
( <number of milliseconds> ) alongside the other fields you are setting.
