My workflow process requires me to escalate an issue to 2nd level suppor which consist of Product Team and Operations Team and the team managers are user1 and user 2. I know that jira doesn't support escalation to groups, so would like when I use the escalate button I get a screen with a drop down list with user1 and user2 pre populated.
Is this possible?
Hey,
take a look at this plugin. It might help:
https://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.usergrouppicker
Cheers
Hi guys,
I am opening up this again as I need a beter solution to group picker. I am looking to create a pre populated dropdown menu containing the folollowing "Test1, Test2, Test3", I would like to have the assignee linked to the fields, so when I click the drop down menu "Test1" automatically goes to "User 1".
Please let me know if this is clear or do I need to explain a bit more?
For this you could assign components to test1, test2, test3 with a default assignee for each component.
