How to customize/sort field on the Domain Axis in Sum Numeric Field in Data Plane Report?
Teja
May 3, 2018
I have generated a report which will show Fix Version/s in X - axis but the list is not in chronological order how to do that using Customizer Script?
   Any help would be appreciated.
Thanks in advance.
Tarun Sapra
May 3, 2018
Hello @Teja
You have to customize the chart to have this feature, basically mention the "ordering" of the domain axis.
Please see here - http://www.arsenalesystems.com/docs/display/dataplane/Customizing+Charts+and+Data+Series
From the docs
In the following example, instead of ordering domain categories by default using the magnitude of the numeric result, issue types "Epic" and "Story" are moved to the top of the chart by explicitly specifying sort order:
customizeChart {    category "Epic" order 1    category "Story" order 2    category "Bug" order 3    category "Technical task" order 4    category "Task" order 5    category "Feature Request" order 6    category "Documentation" order 7}
Tarun Sapra
May 3, 2018
Since you are using "FixVersion" thus you can also use "regex" instead of actual hard-coded values.
Teja
May 3, 2018
Hi @Tarun Sapra,
I have been trying to find example using "regex" but could not able find any where.
customizeChart{
axis "domain" title "any text"
from the above script, I can able to change x -axis name but could able sort..
Do you know more examples on regex?
Teju
Tarun Sapra
May 3, 2018
customizeChart {    category ANY order 999          // set the default order of all categories to a max value
categoryRegex ".*Task" order 1  // then order all issue types whose name includes "Task" first
Tarun Sapra
May 3, 2018
Please go through all the sample on the link which I have shared with you.
Teja
May 3, 2018
Sure, Thanks lot.
Tarun Sapra
May 3, 2018
If it works for you, then please upvote/accept answer so that others are helped as well.
