×Hi,
i want to deactivate the jira users through programatically , can any body help which methods support this process in jira
Depends on version of Jira ,you are using.
This is one option, where you remove from jira-users group.
userUtil.removeUserFromGroup(group, user);
None I can think of other than doing a direct HTTP post to http://yourservername/secure/admin/user/EditUser.jspa. Check out and actual request to make the form data to the passed.
EDIT: Ignore the above answer if your question was about doing it within a JIRA plugin.
yes i want to do deactivation with in a jira plugin , how to do this?
