How to decrypt db password for jira for 10.3.5 version
Bhargavi Vasa
We have upgraded jira from 9.5.1 to 10.3.5 version, for 10.x version, password in dbconfig.xml is encrypted with {ATL_SECURED}. How to decrypt the password? Is there a way to decrypt the password
https://confluence.atlassian.com/adminjiraserver102/secured-secrets-by-default-1489471531.html
Philipp Sendek
Hi @Bhargavi Vasa ,
I've found the following page in the documentation that deals with the different encryption options: https://confluence.atlassian.com/jiracore/encrypting-database-password-975040997.html
Depending on which way you chose, the approach can differ. In those sub-pages you also find a command on how to decrypt the database password.
I hope that helps!
Greetings
Philipp
Bhargavi Vasa
I have tried decrypting the password but it says java not found . Any other way that we can decrypt or how we can update password in future in dbconfig.xml file?
