How to delete a user with issue comments
Praveen
Hi, I would like to know if it is possible to delete a user from Jira who has added comments to  issues.
I know that we can disable the user/remove access, but would like to know on how to permanently the user from the application.
Moses Thomas
June 20, 2018 edited
@PraveenYou  can  use this  plugin https://marketplace.atlassian.com/apps/1214301/comment-toolbox-for-jira?hosting=server&tab=overview
Right now it not  possible on  application interface, but of course you  could  crack and do it from  database but not  advisable.
Advice
Don't delete users. Inactivate them. Deleting them can cause errors when JIRA tries to resolve any action they took in an issue. It stores the database id, not their name in issues.  What  i  would do is to  deactivate them,  remove all access group/roles, save the groups some which  they belong  to  some where in case they  return. access to  projects base on single user  of-course could be given  back  by project admin.
There is a ticket already registered in  Jira  https://jira.atlassian.com/browse/JRASERVER-34718
best!.
Grigory Salnikov
June 20, 2018
Inactivating user should complete the task.
At first we wanted to do just the same but later on realized that inactivating is enough and do the trick.
I give an up to @Moses Thomas's advice.
Paul Cope December 12, 2024
Not possible for us. Under GDPR if a user request we delete all of his data which we do get then we are breaking the law as we cannot follow such instruction and are continuing to process such data.
Also this plugin, nice way to profit but we cannot afford such luxury.
If anyone knows how else we can search and delete a users comments so we can then delete the user, please let me know.
Sana Safai
June 20, 2018
If you have ScriptRunner or database access you can move those comments to another user and then remove that unwanted user.
Neeraj Malik September 4, 2019
please share the steps to do that
Ulrich Dreifke January 7, 2020
I am also interested to know how to move the comments.
Sana Safai
January 7, 2020
WARNING: No guarantee that this works or that it won't break your Jira.
Test this in your test environment first and backup your database before making any direct modification to your database.
import groovy.sql.Sqlimport org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface)
ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default")
def sqlStmt = """
UPDATE       "jiraaction"
SET author = 'newusername'
WHERE author = 'oldusername'
Connection conn = ConnectionFactory.getConnection(helperName);
Sql sql = new Sql(conn)
StringBuffer sb = new StringBuffer()
sql.eachRow(sqlStmt) {
    sb << "${it}\t\n"
sb.toString()
Sana Safai
January 7, 2020
Also, the quotation marks may be erroneous, so if you just copy paste it may not work.
