How to delete user avatar / remove with script runner
Manuel
Is there a way to delete or change the user avatar by using script runner?
With the EU GDPR / EU DSVGO we must remove personal user data after a employee left the company.
Some users upload own pictures into JIRA and I need to remove or change it to a default avatar when a user is set to inactive by LDAP.
As far as I know the avatar is saved as base64 in the database. But we don't want to change something direct in the database.
I should get the users with a change of this example script: https://www.adaptavist.com/doco/display/SFJ/Automatically+deactivate+inactive+JIRA+users
I found a script (https://community.atlassian.com/t5/Adaptavist-questions/uploading-a-user-avatar-with-scriptrunner/qaq-p/831020) that is doing some avatar upload but isn't working as expected.
Has anybody created a script that is working?
Best Regards
Manuel
Patrick
January 6, 2020 edited
import com.atlassian.jira.avatar.Avatar
import com.atlassian.jira.avatar.AvatarManager
import com.atlassian.jira.avatar.AvatarService
import com.atlassian.jira.bc.user.search.UserSearchParams
import com.atlassian.jira.bc.user.search.UserSearchService
AvatarService avatarService = ComponentAccessor.getAvatarService()
UserSearchService userSearchService = ComponentAccessor.getUserSearchService()
AvatarManager avatarManager = ComponentAccessor.getAvatarManager()
//Query to get inactive Users
UserSearchParams userSearchParams = (new UserSearchParams.Builder()).allowEmptyQuery(true).includeActive(false).includeInactive(true).maxResults(10000).build()
for (ApplicationUser appUser : userSearchService.findUsers("", userSearchParams)) {
    /*  This will reset the Avatar, but we need to DELETE own Avatars on the Filesystem too.
        avatarService.setCustomUserAvatar(appUser,appUser,0)
    if (avatarService.hasCustomUserAvatar(appUser, appUser)) {
        def a = avatarManager.getCustomAvatarsForOwner(Avatar.Type.USER, appUser.getKey())
        a.each { b ->
            avatarManager.delete(b.getId(), true)
            log.warn("Deleted Avatar " + b.id + " " + b.fileName + " for " + appUser.displayName)
Simon October 1, 2020
Hi @Patrick,
can you please put the code online again?
Patrick
December 23, 2019 edited
its not hard. Please note that "setCustomerAvatar" is not enough here, since you have to delete them to fulfill the GDPR Requirments.
Basically you use the "userSearcherService" to get all inactive users, loop over them and use AvatarManager to delete the CustomAvatars.
We've configured this as a Service so it runs every month. If you still need help - i can share you my code as soon as im back in the office.
Manuel
Hi Patrick,
Sounds good. It would be nice if you can provide me the code.
Best Regards
Manuel
Patrick
Like Manuel likes this
Manuel
Thanks a lot!
Morten Stensgaard
@Patrick - Do you still have this code?
I have 2.5 GB of avatars, that I need to delete :-)
Morten
Patrick
@Morten Stensgaard
Yes, see above
fjodors
May 13, 2019
Hello
Have you tried setCustomUserAvatar method?
From JIRA API https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/avatar/AvatarService.html it sets a custom avatar for a given user.
setCustomUserAvatar(ApplicationUser remoteUser, ApplicationUser user, Long avatarId)
Manuel
Oh, great. I will give a try.
Register Now
