Hi all,
How can I check if a fixVersions value was changed or removed. ie. My fixVersions is "v1.0" and the user removed. I'm use scriptrunner for JIRA ny Adaptavist.
I tried that like below but i saw same value.
def originalIssue = issueManager.getIssueObject(issue.id)
if(issue.fixVersions[0]?.name != orginalIssue.fixVersions[0]?.name){
// My expected is issue.fixVersions[0]?.name value be empty and originalIssue.fixVersions[0]?.name value be old value
Good day, Ahmet!
I am not quite sure if you are doing this for reporting purposes (and you want to run it manually) or automation purposes, but I just want to share that our JQL has an operator to check if Fix Version was changed:
- Advanced searching - operators reference - Atlassian Documentation - CHANGED
This operator can be used with the Fix Version field, and is used to find issues that have a value that had changed for the specified field.
Hopefully this could be of some help for you :)
Ezra ARA | Atlassian Cloud
I am trying to do the same as suggested by you for fixversion but I am not seeing any data. JQL below
fixVersion changed FROM "Version1" TO "Version2" order by created DESC
We are on Jira Cloud
Were you able to solve the above issue? What is the correct query to check if the fix version is changed from one value to another?
Is a post function or validator? If it is a post function, then it must be first in the list of post functions
is it like this? it does not work.
def changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
def changeItems = changeHistoryManager.getChangeHistories(issue)
if (changeItems) {
def changeItem = changeItems.last().getIssue().fixVersions[0]?.name
What does not work? Do you want to get a value from the history? Try to log the changeItems and see what is in the varaible
log.error("change items: " + changeItems.toString())
You can see the output in the atlassian-jira.log file
