How to disable GOT FEEDBACK button,link in Jira 6.0
Adolfo Casari May 28, 2013
I would like to diable this button/link from a Jira 6.0 instance. Is it possible other than recurring to a javascript tweak?
Marian Finch
May 28, 2013
I apologize Adolfo. I didn't realize that this documenation was outdated. A request has been made to have it removed and/or updated. Can you give this a try:
Select the > Add-Ons > Manage Add-Ons > from the drop down select System > select the '+' to expand for the JIRA Feedback Plugin > Select Disable
The Got Feedback box should now be gone. Let me know how it goes :)
Marian Finch
May 28, 2013
Hey Adolfo,
Our doc on How to disable or enable the GOT FEEDBACK button will walk you through the process :)
Let me know if you need anything else!
Sincerely,
Marian Finch || Product Advocate
Hi marian,
in step 5 in that guide, I can't find the issue-collector-feedback module inside Web resources plugin (Add-on key: jira.webresources).
Help us plant more trees
