How to disable\Hide the Edit Button on Jira
VikasBasra March 17, 2015
How to disable\Hide the Edit Button on JIRA based on a custom field value.
Shawn C
March 17, 2015
Updating the Project Permissions and removing users/groups from Edit Issue Project Permissions will disable users from Editing issues:  https://confluence.atlassian.com/display/JIRA/Managing+Project+Permissions
Alexander Richter
August 11, 2016
Is it possible to disable the creation of Issues for a certain user group?
Case is, we have one project with 7 different issue types, that all use different workflows.
Two of the issuetypes should not be able to be created by normal users any more.
I can't configure that with the permission scheme because it would affect to all issuetypes.
I also don't want to use a validator. Then it would only send a error message when someone tries to create an issue. AND conditions are not there on the create issue function in the workflow.
Udo Brand
March 17, 2015
You can't do this based on a custom field. Only based on a status you can achieve this using workflow properties. See https://confluence.atlassian.com/display/Cloud/Workflow+properties
