×Hello everyone,
I would like to disable the sprints feature in my JIRA project. Currently, there are the tabs Backlog and Active sprints. Is it possible to remove the active sprints tab from the project?
I´ve already found the following description (https://confluence.atlassian.com/jirasoftwarecloud/sprints-946603733.html) but I can´t find the feature-area.
Thanks in advance for your support.
Best regards,
Dennis
Hi @Dennis S_
I don't think that you can change the "type" of the project, but you can add a Kanban board to the project and use that. The board filter for the board would then be exactly the same as that for the project.
Hope this helps
You can simply turn off the Sprint feature in "Project Settings -> Features". However, you can do it only in case your project is "Team managed".
To clarify the problem:
There are the following three different ways to create a project:
The mentioned project has been created as scrum software development project. Now, I would like to change it into a kanban software development project. Is this possible?
Thank you!
