How to display Resolution Date in the JIRA Issues Calendar
Mauro Cendon January 14, 2014
Hi Resolution Date not figures in the JIRA Issues Calendar Gadget select. I try to copy the value of the resolution date to a date custom field (to be used in the gadget) with a "Copy Field to Another Field" Post function, but also not appears the Resolution Date as an option. Can you help me? Thank you for advance
After install the JIRA Suite Utilities plugin, I created a post function in the project Workflow, on the "Resolve" transition. For this post function, I used the "Copy Value From Other Field" option and selected "Resolved" to be the Source Field and created a datetime Custom Field to be the Destination Field.
Now, everytime I close an issue, this field is populated.
After that, I choose this custom field to be the "Date to Display" in the gadget and it worked!
Raina Arjona
Thank you for posting this! I had the same problem, but your resolution works great.
Read the story
