How to display only certain types of linked issue in search result
Pinaki Basu
Hi
When I am displaying links in the result of a search filter, JIRA displays all the links. I want to control the type of link JIRA displays. We have two links relation "relates to" and "tested by". In the result of a search filter, I want to display only the "tested by" links. Is there any way I can control which links I can displace. I would like to know if there are any plugins available in the Marketplace.
Cheers
MC
January 24, 2021
For sure is late for Pinaki Basu, but I just want to add the correct answer so people don't have to look further in other questions.
If you want to: "We have two links relation "relates to" and "tested by". In the result of a search filter, I want to display only the "tested by" links."
Simply add to your query:
AND issueLinkType = "tested by"
Cheers.
Luc Leblanc May 7, 2020
Hi, same challenge for a lot of people here !
To filter issues base on the link, I use this JQL : issue in linkedIssues('key isse','has to be done after')
But I did not find a way to display the "name" of the link in a query.
CécileV May 20, 2021
I have the same need: in the query result, I'd like to display the issuelink type, not only the issues that are linked.
Any clue on how to proceed?
Artem Astapov
March 27, 2019
The first thing i wanted after link column has been used is DO NOT show all linked issues, but show only specific.
ashleysutcliffe
May 21, 2019
We have the same issue - we use specific link types but cannot only show the relevant linked tickets in a dashboard, which makes reviewing tickets for a specific purpose very difficult as tickets are often multiply linked.
Ewa Boloczko
Hi @Christian Czaia [Decadis AG], I wanted to make it life again....my users are asking for that too. I's like 4 years later, so maybe there are some options now?
Thanks, Ewa
May 15, 2014
Hey,
maybe you want to have a look at Jamie's script runner plugin which extends the JIRA JQL search:
https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+JQL+Functions#ScriptedJQLFunctions-hasLinkType(linktypename)
Cheers
Pinaki Basu
Thanks for the reply. At the moment I can search based on the linktypes. The problem is when any JIRA issue is linked to different links with different link types. At the moment I want to display only certain type of link. So if any issue has three different linktypes, I want to display only one link types.
