We have a 4 node cluster for JIRA. We are using F5 load balancer to distribute traffic. Due to increase in rest api calls from external applications we are experiencing some performance issues. So, we want divert rest api calls from external applications to Node 4. I read this https://confluence.atlassian.com/enterprise/traffic-distribution-with-atlassian-data-center-895912660.html. But, not sure how to implement in our F5 load balancer. Can someone please give some detailed steps to implement this? Thank You.
Hi Jonnada,
Did you made it worked? I am also trying to setup same with F5 load balncer.
Please share the details if you done so?
Sanu P Soman
@Sanu Soman Hi. I have implemented it. It works great. Implement the below irule in F5. Thanks.
when HTTP_REQUEST {
log local0. "New code"
set referrer_host [ URI::host [HTTP::header value Referer]]
log local0. "host: [HTTP::host]"
log local0. "uri: [HTTP::uri]"
log local0. "path: [HTTP::path]"
log local0. "Referer: $referrer_host"
if { ([HTTP::header exists "Referer"]) } {
if { $referrer_host eq "" } {
set referrer_host "none"
if { !($referrer_host contains "jiratest.corp.chartercom.com") } {
log local0. "referrer is not equal to jira"
if { ([HTTP::uri] contains "/rest/") } {
log local0. "referrer is not equal to jira and contain rest"
pool JIRA-test-external-pool
} else {
pool JIRA-test-pool
} else {
log local0. "referer is jira"
pool JIRA-test-pool
} else {
log local0. "Referer does not exist"
if { !([HTTP::uri] contains "/rest/") } {
pool JIRA-test-pool
} else {
Great and many thanks for sharing it.
Is your JIRA running with SSL enabled? If so, do we need to terminate SSL at F5 level to configure this?
Dear @Jonnada Kiran,
you have to terminate SSL on F5 otherwise you cannot filter, because the path information will be encrypted.
So long
Thomas
Hi Thomas,
We have the same requirement where we want to redirect external Rest API only to specific node we have 4 node and we want to redirect external REST traffic to node 4.
We have written iRule for that but we observed few thing
1. Jira becomes slow.
2. Xray plugin is not working as expected like "Test" tab is not appear on the screen.
Dear @Sachin,
as I wrote, if you will try to load balance HTTP traffic depending on the path information of the URL, it may not be encrypted.
This slow Jira will result (I guess) from Jira's own communication over the REST API. Best do not balance this to only one node.
For the XRay Plugin, best ask the vendor. They should know about their plugin engine.
So long
Thomas
Hi Thomas,
Thanks for reply.
So what you r saying is we should not redirect REST API call to specific one node if we have SSL on F5?
And if we want to redirect then we have to skip ssl?
Sachin
@Thomas Deiler@Sachin@Sanu Soman Sorry for replying late. Redirecting traffic to a node raised indexing problems between nodes.
@Jonnada Kiran: Did you experience this? Did Atlassian confirm about this? what is solution for this then?
Arlassian recommended not to divert rest calls till they find a solution
@Jonnada Kiran Thanks for reply. Does they have created bug or any issue for their developer for this?
Hi all,
I see that this is some confusion around LoadBalancing, so to prevent the uncertainty please let me clarify some points. :)
How you can check that session affinity is fine.
x-anodeid: i-02b2b80fafcf9ad1d
Hope this helps
Cheers
We have written the same iRule which target only external REST API.
Can you please explain 2nd point i.e "This is very crucial to make sure that you redirect traffic only from External application (bot), not from the normal user. In another case, you will be break session affinity which leads to different functional and performance problems."
In that you mentioned *Not from the normal user* what does it mean? and how do we check this?
Sachin
Sure, please let me help with this part:
That means, that user sessions should not be part of the redirect config. They should always talk to the same node.
see the section (How you can check that session affinity is fine. ) in the comment above
Cheers.
@Andriy Yakovlev [Atlassian]@Thomas Deiler
This is the iRule we have implemented. Can you please check. it?
when
HTTP_REQUEST {
if
{ !([HTTP::header value Referer] contains "jirapbguat") and ([HTTP::uri] contains "/rest") and ([HTTP::uri] ne "/login.jsp") }
{ node 10.233.128.120 8080 }
Sachin
separating REST from 'normal' calls can be done by analyzing the header information of HTTP requests, sent to the load balancer from the network. Everything that carries /rest/api/ in the destination URL is directed to a specific node.
As your company has invested in premium product, there should be a comprehensive documentation about F5 traffic balancing. I cannot help further, I am not familiar with this product.
So long
Thomas
@Jonnada Kiran and @Sanu Soman,
keep in mind, that Jira is communicating with itself via REST. So best you do not balance requests from Jira.
Jira will request the F5 from its external network interface and not communicate from localhost to localhost.
This is not valid for Confluence, only Jira.
So long
Thomas
Hi all,
To clarify @Thomas Deiler answer:
Jira UI operations also use same REST API, so you should be careful here and redirect traffic to specific Node4 only from External application (bot), not from normal user. In another case you will have user session expired all the time.
There is no single way how you can do this, a couple of options to name:
If referrer != app.yourdomain.com and the request ~ /rest:
If the page requested == /login.jsp:
Direct traffic to Node 1 or Node 2 or Node 3 //normal traffic
Else:
Direct to Node 4 //external REST API traffic
Hope this helps.
Register now
