How to do a list using the markup language with newline
samuelbuck September 4, 2018
I would like to make a list like this:
This is a list
  • Item A
    • Item A.a
    • Item A.b
  • Item B
Using the markup language like this:
+This is a list+ // * Item A // ** Item A.a // ** Item A.b // * Item B
Mohamed Riza
September 10, 2018
Hi Sameul,
If you want to to specify this all in one line, then this should done with a double backslash as follow:
* Item A  \\ ** Item A.a \\ ** Item A.b  \\ ** Item B
samuelbuck September 10, 2018
Hi Mohamed,
Is there a specific version of JIRA that this works/ doesn't work on.
I gave the example a try and this is what I got.
Thanks for your time.
Mohamed Riza
September 10, 2018
I tried this on Jira 7.8.0. Can you clarify which version you are using?
samuelbuck September 18, 2018
Clicking on "About JIRA", It says JIRA v7.6.4
Let's build A Rovo Agent 🤖
Save your spot
