I have a custom field that's a select list with "Yes" and "No" options for values. This works:
#{if (%{'${elmYnMigration}'.equals('Yes')})}
... show this content ...
#{end}
How does one do a "not equals" version?
Piling on... is there an "or" construct? What about an "else"?
Thanks in advance for any feedback...
-Gene
Hi @Gene Smilgiewicz
Please try the following code:
#{if (%{'${elmYnMigration}'==='Yes'})} …Show Content Here… #{end} #{if (%{!('${elmYnMigration}'==='Yes') || !${elmYnMigration}})} …Show Other Content Here… #{end}
What is the version of Xporter for JIRA that you're using ?
Kind Regards,
Fábio Antunes
Currently Xporter for JIRA does not have an "else" statement, but you could use another if as workaround, example:
#{if (%{'${elmYnMigration}'==='Yes'})} ... show this content ... #{end} #{if (%{!'${elmYnMigration}'==='Yes'})} ... show other content ... #{end}
Kind Regards,
Fábio Antunes
Hi, I tried to create an Or condition in an if statement but it's not working and in the documentation I can't find a proper example. I need to know what is the proper sintax for that. Could anyone help me, please?
I have the same issue when it comes to filtering certain link types from an issue.
#{for tests}
#{for a=Tests[n].LinksCount}
#{if (%{'${Tests[n].Links[a].LinkType}'.equals('tests')})}
${Tests[n].Key}
#{end}
#{end}
#{end}
I need an IF to get my all links except the TESTS one. I tried:
#{if (%{!'${Tests[n].Links[a].LinkType}'.equals('tests')})}
#{if (%!{'${Tests[n].Links[a].LinkType}'.equals('tests')})}
#{if (!%{'${Tests[n].Links[a].LinkType}'.equals('tests')})}
#{if !(%{'${Tests[n].Links[a].LinkType}'.equals('tests')})}
None of those work.
Any idea?
if
'${elmYnMigration}'!=
'Yes'
works for me
Thanks for chiming in, Fábio.
Without an #{else} I was forced to stack #{if} statements... an #{or} would be helpful.
BTW, your suggestion for not equals (#{
if
'${elmYnMigration}'
'Yes'
) did not work for me. Interesting variation of the Xporter syntax there.
-Gene
Learn more
