How to dynamically alter workflows based on key words in the issue description
Dan Pinvidic
February 4, 2016
This question is in reference to Atlassian Documentation: Advanced workflow configuration
I have found some existing workflows in our version 4.3 JIRA system which allowed changes to transitions based on key words defined in the issue field.  The group responsible for this is no longer available. I can't find any documentation on how this actually works. Is there supporting documentation?
Here is an example:
SIGHTING_STATE=true|false                      // adds "sighting" state for silicon issues not yet confirmed as bugs
SIGHTING_REPORT_SUBTASK=true|false  // "sighting report" subtask is created on transition to "sighting" state
Dan Pinvidic
February 5, 2016
Thanks everyone, I will contact our admin to see what plug-in we have.
I think I have a better understanding now of how this would be done.
Dan
Dane Kantner August 16, 2017
were you ever able to determine this?
Boris Georgiev [Appfire]
February 4, 2016
If you can attach an xml export of your workflow - then probably someone might be able to provide further help.
Vasiliy Zverev
February 4, 2016
I assume that there was a plugin which analised these fields. See plugin list and try to find one to provide this functions.
Nic Brough -Adaptavist-
February 5, 2016
That's my feeling too - there's no such functionality in the core workflow in JIRA between versions 2 and 7.  It looks like an instruction of some sort for a post-function to pick up.
Read the story
