How to edit a field on the fly when in the filter view
AJ
I want to be able to edit a field (for example a date field, or assignee field) while I am in the filter view without going inside that issue.   I know this functionality exists in the structure plugin, but was wondering if there is something in default Jira or by using some free plugin to achieve this functionality?
Nguyen Tran
March 13, 2018
I think this plugin might be able to help you
https://marketplace.atlassian.com/plugins/com.moresimp.jexcel/server/overview
Or you can click on the "..." and choose "Edit" for a particular issue in the filter view.
AJ
The "Edit" option is not what I was looking for because that means I have to open up each issue to make the edit.   I looked at the plugin you mentioned, but does not seem like it has what I am looking for, but I will try it out.
Nguyen Tran
March 13, 2018
Let me know how it goes.
AJ
I looked into the plugin.  I might do what I want, but it is a "heavy" plugin.  It adds in a menu item at the very top.   I was trying to find an easier way to handle this.
Colleen Gotling
Did this work for you or did you find another option?  What you described is exactly what I need to do as well.
Like # people like this
