How to edit a read only customfield using Behaviours
Sam March 7, 2025
I created three custom fields based on one field i want to set options for remaining two , but i want remaining two fields as read-only and these three are mutli-select fields
script i am using in behaviours
import com.onresolve.jira.groovy.user.FormField
import com.atlassian.jira.issue.customfields.manager.OptionsManager
def optionsManager = ComponentAccessor.getComponent(OptionsManager)
def customFieldManager = ComponentAccessor.customFieldManager
FormField oneField = getFieldByName("Function Group (all)")
FormField twoField = getFieldByName("Domain Group")
FormField threeField = getFieldByName("Only Domain")
twoField.setReadOnly(false)
threeField.setReadOnly(false)
def selectedValues = oneField.getValue() as List
twoField.setFormValue([])
threeField.setFormValue([])
def twoCustomField = customFieldManager.getCustomFieldObject(twoField.getFieldId())
def threeCustomField = customFieldManager.getCustomFieldObject(threeField.getFieldId())
def issueContext = getIssueContext()
def twoConfig = twoCustomField.getRelevantConfig(issueContext)
def twoOptions = optionsManager.getOptions(twoConfig)
def threeConfig = threeCustomField.getRelevantConfig(issueContext)
def threeOptions = optionsManager.getOptions(threeConfig)
def optionsToSetForTwo = []
def optionsToSetForThree = []
twoOptions.each { println "Two Option: ${it.value}, ID: ${it.optionId}" }
threeOptions.each { println "Three Option: ${it.value}, ID: ${it.optionId}" }
selectedValues.each { value ->
    def parts = value.toString().split('-')
    if (parts.size() >= 2) {
        def twoValue = parts[0]
        def threeValue = parts[1]
        // Accumulate options for "Two"
        twoOptions.findAll { it.getValue() == twoValue }.each { twoOption ->
            optionsToSetForTwo << twoOption.getOptionId().toString()
        // Accumulate options for "Three"
        threeOptions.findAll { it.getValue() == threeValue }.each { threeOption ->
            optionsToSetForThree << threeOption.getOptionId().toString()
twoField.setFormValue(optionsToSetForTwo.unique())
threeField.setFormValue(optionsToSetForThree.unique())
twoField.setReadOnly(true)
threeField.setReadOnly(true)
Clark Everson
Hi @Sam
In scriptrunner behaviors down below the script box you should be able to set read only there rather than in a script. This generally works for meScreenshot 2025-03-31 at 10.10.19 PM.png
