How to edit the fields that show up in the sidebar edit panel
Colin Fischer
February 5, 2018
If I am in one of my boards and I click on a task a sidebar edit panel comes up on the right hand side with a subsection of the tasks properties that you can quickly edit. However we don't have priority in here and I would like it but for the life of me I can't figure out what that panel is referred to or how to edit what gets displayed on it. Any help would be greatly appreciated.
Thanks.
Thomas Deiler
February 5, 2018 edited
Dear @Colin Fischer,
go to the agile boards configuration. There is a tab (Issue Detail View) where you can select by drag and drop which fields to display. Even the order can be set.
So long
Thomas
Thomas Deiler
February 8, 2018
did you where successful?
So long
Thomas
Like • Becky Moshenek likes this
Anton Kan September 12, 2018
I don't have "Issue Detail View" tab in my board configuration. How can I bring it back?
Like • Dinesh Nagar likes this
Marcus Mattsson October 3, 2018
I have the same issue, the "Issue Details View" option in the board configuration was removed with the new Jira design overhaul.
DSell
Hello @Thomas Deiler , Can the issue layout be set globally or as a default going forward with new jira projects?
Thomas Deiler
April 10, 2021
Dear @DSell ,
probably this link can help.
So long
Thomas
guismb July 19, 2019
It's now called "Issue Layout" and you can have different layouts for different Issue Types. That is for the Right Panel in the Issue View Page. For the right panel in the "backlog" view, under board settings you still have the Issue Detail View option.
brooke February 20, 2020
I have 2 issue screen schemes set up--default and defect. But the side panels in both the backlog and the active sprint only use the default scheme, so the issues that use the defect scheme don't display the custom fields in the sidebars.
hanan rokach November 12, 2018
+1, "Issue Details View" removed
Janet
October 6, 2022
It is under Board, Configure,  Issue Detail View
Dinesh Nagar
March 7, 2023
I do not see it in the Board Configure screen. I only see this:
Janet
July 9, 2024
Hey Dinesh - its not in that menu its under your KANBAN Board menuScreenshot 2024-07-09 at 12.46.12 PM.png Screenshot 2024-07-09 at 12.47.44 PM.png
