I am trying to edit a comment in jira using jira-python, but I couldnt find anything.
I know Add_comment will add a comment, but I also want to know how to edit a comment. thanks~!!
You can edit a comment by first getting the comment ID. If you hover over the link icon of a comment(see screenshot) the ID should be contained in the link URL.
With the commentID you can then update the comment
jira_options={'server': 'http://<jira_url>'}
jira=JIRA(options=jira_options,basic_auth=('username','password'))
comment = jira.comment('ALPHA-27', '10100')
comment.update(body = 'the text here will replace the text in the comment')
I'm sure there is a more streamlined method of obtaining the comment ID, but that should work for the sake of testing.
Hello, i need solution how to make internal comment external programatically.
I've found flag called jsdPublic, but it looks not working if I do update using PUT request.
when I edit a customfield, it returns
response text = {"errorMessages":["Internal server error"],"errors":{}}
do you know how to fix this?@Shaun Seaver
