Hi, We have a requirement to access JIRA projects from outside firewall without VPN, using Web Access Gateway. Can we use this for JIRA or Confluence using any plugins or any other means.
Thank you,
Siva
Hi Siva,
Are you talking about the PowerShell Web Access? If I remember correctly that only allows access to Powershell over the Internet.
If you're talking about RD Web Access that will allow RDP access that would allow you to use Remote Desktop.
If neither of those are what you're referencing perhaps link to the product page for the Web Access Gateway you're referring to and we'll go from there.
Branden
