×Hi, I need help because Im a beginner.
I have to control the following in a jira plugin. When custom field A is empty other custom field B should be disable or read only.
Please help!!
You don't need to do this via a plugin. You can include javascript in the custom field description which activates and disables field B depending on state of field A.
You can also use the field configuration schemes if you want to have behaviour specific to a project
http://confluence.atlassian.com/display/JIRACOM/Using+JavaScript+to+Set+Custom+Field+Values
Thanks for the information. I'll take a look at those links and I will comment.
Yes, I've been taking a look and it seems that this is what I need. Thanks again!
I am not able to open first link .. please provide link sgain or any alternative.
