How to enable velocity chart on JIRA dashboard
SHANAVASH MOHAMED
How to enable velocity chart on JIRA Dashboard without gadget plugin, any options if available. Please give me any suggestion.
32 votes
Boaz Katz
i suggest to vote for this issue and make it a priority
https://jira.atlassian.com/browse/JSWSERVER-10762
KevinBrennan May 23, 2023
Done!
Linda Hufland December 14, 2023
Great idea! I voted for it.
Som_RVS April 6, 2024
As an alternative, to track resource / sprint velocity as a dashboard gadget, I can recommend our app. The app comes with couple of gadgets to track team member's velocity in a sprint and also a complete sprint status overview.
Sprint Velocity & Status Gadgets
Disclaimer : I am part of the team which developed this app
Like • 2 people like this
Ivannia Chinchilla
May 28, 2024
Is this App for free?
Som_RVS May 28, 2024
Hi @Ivannia Chinchilla
Yes
Simon Otten July 24, 2024
Hi @Som_RVS , I'm trying out this gadget but it barely shows any issues as completed even though they are completed in the Jira internal velocity chart. What does your app look for to define issues as completed? It doesn't seem to be the "Done" status
Som_RVS July 24, 2024
Hi @Simon Otten
Thanks for trying out our add-on.
The app does look for the "done" status.
Can we get on a zoom call to have a look at the issue.
Please let us know at support@rvsoftwares.in for a suitable time and we will schedule the call accordingly.
10 votes
Kirill Skuibida
By default, there's no way to put Velocity charts to the dashboard unless you use some plugin i.e. https://marketplace.atlassian.com/apps/1215768/agile-velocity-chart-gadget?hosting=server&tab=overview
Max Cascone
August 21, 2019
How is this even possible that JIRA has no native way to show velocity charts in a dashboard. How is it acceptable. I find this so hard to believe. One of the most basic charts in all of Agile and they can't support it? I have to pay for a 3rd party extension for one of the most baseline capabilities in an ALM tool? I know there's a report, but i want it in a dashboard.
Who's got a link to an existing feature request that will go unsatisfied for years?
Like • 46 people like this
ralphsmith80
September 6, 2019
Agreed. This is a pretty big miss. Team velocity is kind-of the main point.
Like • 15 people like this
Max Cascone
September 6, 2019
It's like, THE point! Of points! So you can guage your performance over time! And they INSIST on so many charts and gadgets only supporting points.... and then to not have a velocity gadget?
I'm yelling, sorry. It just baffles me sometimes how half-baked this tool can be sometimes, when it's so powerful and awesome in other ways.
Like • 17 people like this
Craig Cockburn
Value delivered is the point. Story points is only a planning tool.
Like • Deleted user likes this
Sha-Ron Cassel
Is there an update on this?  Is it still not available?
Jenny Vessgård
April 7, 2022
I need it to!
Alexa
Same
Same
Linda Hufland November 7, 2023
I need it too
Like • Jake likes this
Ivan Garcia _Appfire_
Apparently no updates on this yet... However, if you really need it, in the meantime I'd suggest our app Dashboard Hub for Jira – Custom Charts & Share Reports as a workaround.
It includes a Scrum Velocity ready-to-go gadget that might be helpful while you wait.
Hope it helps!
Robin Surland December 12, 2023
@Ivan Garcia _Appfire_ unfortunately we cannot use your apps because you don't have clear EUAs on how you handle our data. We couldn't get it through legal.
Hi @Robin Surland â€“ Did you navigate our documentation and the Appfire Trust Center? We have plenty of information regarding security. If you still have any doubts, you can also raise a ticket in our support center.
Hope it helps, Appfire strives to be transparent in terms of security.
6 votes
Michelle Douville
December 18, 2019
As a work around I added a 'Text' widget to the dashboard which supports html and then embedded the velocity chart url into an iframe into the dashboard.. like this:
<iframe width="900" height="1000" frameborder="0" src="URL to Velocity Chart"></iframe>
Shaun Alsobrook December 19, 2019
Can you please send me a link to how to add "Text" widget?  I'm triyng to put one of these together
Michelle Douville
December 22, 2019
I just search for the 'text' gadget and it showed up in the last of available gadgets for dashboards.
Shaun Alsobrook December 23, 2019
Thank you
David Yeo
January 29, 2020
Can no longer find the text widget?
Like • 7 people like this
Deleted user March 10, 2020
I used the Custom Content gadget and added the URL to the velocity chart.
Brittany Funk
Neither Custom Content Gadget or Text widget is available from what I can see. Did something change?
Like • 13 people like this
Scott Rose
July 14, 2020
" then embedded the velocity chart url into an iframe into the dashboard.. like this:"
How/where did you create the velocity chart?  Did you do that manually?
Alla
April 9, 2021
It is visible in the sprint reports: switch report -> Velocity chart.
Kamalpreet Kaur
April 1, 2022
Cannot See Custom Content gadget or the text widget, can anyone help?
Jeremy Jedlicka
@Kamalpreet Kaur the Text Gadget is disabled by default for security purposes.  Have your Admin enable it if needed.
Like • Nicolas Lefebvre likes this
Tom Devoil
December 5, 2024
This was very clever!
Theresa McFarlane
Hi there!
Go to your scrum board > click on reports> select velocity
I usually add a link to the team assets/reports on the TEAM Dashboard if i can't add it to the main report dashboard. I also do custom reports on the main reporting dashboard as well to mimic the REPORTS feature.
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
