How to execute shell script with parameters in postfunction using ScriptRunner
Tammy Robinson
May 29, 2019 edited
When my request is submitted, I need to execute a script and pass parameters from my  request. Are there any examples on how to achieve this? I created a test and added this line into my workflow postfunction, but nothing happens. Can someone please provide insight on how to do this using ScriptRunner?
"ssh myid@myjiraserver.com test.sh".execute()
DH
Hi @Tammy Robinson , this works in the Scriptrunner console. Maybe this can work in your post-function also?
def command = 'ls -al'
def proc = command.execute()
proc.waitFor()
log.warn "Process exit code: ${proc.exitValue()}"
log.warn "Std Err: ${proc.err.text}"
log.warn "Std Out: ${proc.in.text}"
Alexey Matveev
May 29, 2019
You would need an app for it. For example, Power Scripts, ScriptRunner, MyGroovy, Groovioli and so on.
If you want to use the Power Scripts app, then you should execute the system routine:
https://confluence.cprime.io/display/SIL/system
Tammy Robinson
Hi Alexey,
Thank you for replying. Sorry I forgot to mention that I am trying to execute this in ScriptRunner.
Tammy Robinson
Any ideas on how to do this using ScriptRunner?
Register here ⬇️
