I want to fill a database information custom field with REST API.
/rest/api/2/issue
I filled other types of custom fields, such as; summary or text fields.
Howver, I can not find any database custom field example.
Thanks in advance
Im not aware that there is a database type of customfield.
If you want to fill a customfield with api make sure the customfield is on the create or edit screen.
Look for editmeta in your link
Regards
