Hi all,
I want to filter out one specific component. When I googled, I read that the correct syntax is:
project="myProjet" AND (component != XYZ)
The problem here is that all issues without any component, are also excluded. That's not what I want. I want to show everything, but not component XYZ.
How do I do that?
Emelie
Add the following…
… AND Component is not Empty
I added this query:
project="myProject" AND (component != XYZ) AND (component != empty)
But it still filters out all issues without components.
try this...
project="myProject" AND (component != XYZ) AND (component is not empty)
That would be
project="myProject" AND ((component != XYZ) OR (component is empty))
although I fail to understand why the OR (component is empty) part is necessary (I tested it on my instance, it really is). The operators reference (https://confluence.atlassian.com/jirasoftwareserver/advanced-searching-operators-reference-939938745.html#Advancedsearchingoperatorsreference-NOT_EQUALSNOTEQUALS:!=) doesn't seem to cover this case.
EDIT: OK, I'm not sure if I missed that part or if the text has been updated, but the operator reference does cover this case:
The operator won't match a field that has no value (an empty field). For example,
component != fred
will only match issues that have a component and this component isn't "fred". To find issues that have a component other than "fred" or have no component, you should typecomponent != fred or component is empty
(Though I still fail to understand why anyone would have designed it that way).
Thanks a lot!! helped me to solve in my project!
Register today!Online forums and learning are now in one easy-to-use experience.
