How to find all workflows which are using postfunctions of a plugin
francis
We need to upgrade a JIRA, but one of the plugins is not compatible.
How can we find all the workflows which are using the workflow functions from this plugin ?
5 votes
Henning Tietgens
August 26, 2013
You could use the Script Runner plugin to search for more detailed uses. I wrote a script to create a list which than can be used e.g. in Excel for further investigations.
import com.atlassian.jira.workflow.JiraWorkflow
import com.atlassian.jira.workflow.WorkflowManager
import java.util.regex.Matcher
String searchText = 'com.googlecode.jsu.workflow.'
WorkflowManager workflowManager = ComponentAccessor.getWorkflowManager()
Collection<JiraWorkflow> workflows = workflowManager.getWorkflows()
String result = "Workflow;Function;Type;Action;Step\r\n"
workflows.each{workflow ->
    workflowXml = workflow.descriptor.asXML()
    Matcher m = workflowXml =~ /${searchText}/
    if (m.find()) {
        String workflow_name = "${workflow.name}${if(!workflow.isActive()){"(inactive)"} else ''}${if(workflow.isDraftWorkflow()){"(draft)"} else ''}"
        def wf = new XmlParser().parseText(workflowXml)
        List<Node> wf_flat = wf.depthFirst()
        wf_flat.each{
            if (it.text() ==~ /.*${searchText}.*/){
                result += "$workflow_name;${getNodeInfo(it,searchText)}\r\n"
result
String getNodeInfo(Node n, String search) {
    String nodetext = ''
    nodetext += "${n.text() - search}"
    def p = n.parent()
    while (p) {
        switch (p.name()) {
            case 'post-functions':
                nodetext += ";post-function"; break
            case 'validators':
                nodetext += ";validator"; break
            case 'conditions':
                nodetext += ";condition"; break
            case 'action':
                nodetext += ";${p.attribute('name')} (${p.attribute('id')})"; break
            case 'step':
            case 'global-actions':
                nodetext += ";GLOBAL"; break
            case 'initial-actions':
                nodetext += ";INITIAL"; break
        p = p.parent()
    return nodetext
You have to adapt the searchText to match the plugin.
Henning
francis
That's a cool approach, not requiring to access JIRA 'behind the scenes'
Certainly a candidate for a build-in script (IMO)
Bryan Karsh
April 15, 2016
Henning - this a beautiful solution. Thanks for sharing!
Bryan Karsh
April 21, 2016
@Henning Tietgens  – quick question. in the getNodeInfo method – why are you using the minus operator here:
It looks like it's removing the search term from nodetext...?  Not sure why you are doing that. Any tips / insight much appreciated!
Henning Tietgens
April 21, 2016
You're right. It's only for shorter list entries.
Cyril Egan January 31, 2019
Hi @Henning Tietgens
This is brilliant!  I am planning a Jira upgrade with numerous plugins and numerous workflows.  Remembering what post-functions I used and where I used them is now infinitely easier for doing my testing.  Thank you!
Adam Kopleff
September 1, 2022
@Henning Tietgens
Seeing that this was last updated in 2018.  We are preparing to migrate to the Cloud finally and curious if this script is still applicable before I try it?
Update:  I did run it and it worked.  I am not that familiar with scripting myself, is there any one that could help me get results back ignoring inactive workflows?  Our environment is a mess and we have tons of copies of workflows that sit inactive.
Adam
8 votes
Henning Tietgens
June 17, 2019
Another updated version, now building the search string from the modules used by the app identified by an app key. Reporting used custom fields, too.
package eventim.scripts
import com.atlassian.jira.plugin.workflow.AbstractWorkflowModuleDescriptor
import com.atlassian.plugin.PluginAccessor
String appKey = "com.innovalog.jmcf.jira-misc-custom-fields"
String result = ""
PluginAccessor pluginAccessor = ComponentAccessor.getPluginAccessor()
def p = pluginAccessor.getPlugin(appKey)
if (p) {
def modules = p.getModuleDescriptors()
def implementationClasses = modules.findAll{
it instanceof AbstractWorkflowModuleDescriptor
}.collect{
it as AbstractWorkflowModuleDescriptor
}*.implementationClass.name
def searchText = implementationClasses.join('|')
log.debug "searchText: $searchText"
result = "Workflow;Function;Type;Action;Source-Step<br>"
def workflowXml = workflow.descriptor.asXML()
if (m.find()) {
String workflow_name = "${workflow.name}${workflow.isActive()?"":"(inactive)"}${workflow.isDraftWorkflow()?"(draft)":""}"
log.debug "Found: $workflow_name"
wf_flat.each{ node ->
if (implementationClasses.contains(node.text())) {
log.debug "Found node $node"
def implementationClassName = implementationClasses.find{it == node.text()}
def nodeInfo = getNodeInfo(node, implementationClassName)
if (nodeInfo) {
result += "$workflow_name;$nodeInfo<br>"
result += "<br>Customfields<br>"
def customfieldmanager = ComponentAccessor.customFieldManager
result += customfieldmanager.customFieldObjects.findAll{
it.customFieldType.key ==~ appKey + /.*/ ||
it.customFieldSearcher?.descriptor?.toString() ==~ appKey + /.*/
}.collect{
"$it.name ($it.customFieldType.name, ${it.customFieldSearcher?.descriptor})"
}.join("<br>")
result
static String getNodeInfo(Node n, String implementationClassName) {
def valid_action = false
def valid_function = false
def valid_step = false
n = n.parent()
if (n.name() in ['function','condition','validator']) {
nodetext += implementationClassName + ";"
def p = n.parent()
while (p) {
switch (p.name()) {
valid_function = true
nodetext += "post-function;"; break
case 'validators':
nodetext += "validator;"; break
case 'conditions':
nodetext += "condition;"; break
case 'action':
valid_action = true
nodetext += "${p.attribute('name')} (${p.attribute('id')});"; break
case 'step':
valid_step = true
nodetext += "${p.attribute('name')} (${p.attribute('id')})"; break
valid_step = true
nodetext += "GLOBAL"; break
valid_step = true
nodetext += "INITIAL"; break
p = p.parent()
if (valid_action && valid_function && valid_step) {
return nodetext
} else {
return ""
Have fun,
Henning
Alvin
June 17, 2019
Hi @Henning Tietgens ,
Thank you for keeping an extra eye on this problem, but there is no workflow step returned, only custom fields
Customfields
Calculated Date-Time Field (JWT Migration) (Calculated Date-Time Field (by JWT), com.atlassian.jira.plugin.system.customfieldtypes:datetimerange (Allow searching for a date and time that is between two other dates and times))
Calculated Text Field (JWT Migration) (Calculated Text Field (by JWT), com.atlassian.jira.plugin.system.customfieldtypes:textsearcher (Search for values using a free text search.))
Henning Tietgens
June 17, 2019
I updated the script again to look for the implementation class to find workflow functions. Please try again.
Alvin
June 18, 2019
Good day! Sorry to disturb you but still it does not return the validators, only post functions, I have tried to download xml file and search for validators, I found com.innovalog.jmwe.plugins.validators.FieldRequiredValidator and use it on appKey.
Still returning null as result. Have you tried to check validators also using the script? Thank you!
Best Regards,
Alvin
Henning Tietgens
June 18, 2019
Hi Alvin,
com.innovalog.jmwe.plugins.validators.FieldRequiredValidator is not the appKey. Please go to Manage Apps in Jira and click on the corresponding app (plugin). There you could see the app key. Maybe it's com.innovalog.jmwe but this is just a guess.
E.g. this is for Jira Toolkit Plugin
Capture 2019-06-18_10-28-49_AM.pngBest regards,
Henning
Alvin
June 18, 2019
Thank you for that, I have used it before but it only returns post-functions, not the validators.
Henning Tietgens
June 18, 2019
Could you please add
import org.apache.log4j.Level
log.setLevel(Level.DEBUG)
after the imports at the beginning of the script and tell me the log output and the validator part of the xml export of the workflow?
If you want to limit the output to your test workflow you could add
workflows.findAll{it.name == 'Testworkflow'}.each{workflow ->
to the corresponding line (replacing Testworkflow with the name of the workflow).
Henning
Alvin
June 18, 2019
2019-06-18 20:03:42,307 DEBUG [runner.ScriptRunnerImpl]: searchText: com.fca.jira.plugins.workflowToolbox.CascadeSelectComparatorCondition
|com.fca.jira.plugins.workflowToolbox.IfMatchesRegexpCondition|com.fca.jira.plugins.workflowToolbox.AllowedLinksCondition
|com.fca.jira.plugins.workflowToolbox.AnyIssueCondition|com.fca.jira.plugins.workflowToolbox.MathExpressionsCondition
|com.fca.jira.plugins.workflowToolbox.ParsedTextsCondition
|com.fca.jira.plugins.workflowToolbox.ExceptAssigneeCondition
|com.fca.jira.plugins.workflowToolbox.ExceptReporterCondition
|com.fca.jira.plugins.workflowToolbox.NotInProjectRoleCondition
|com.fca.jira.plugins.workflowToolbox.OnlyUserInCustomFieldCondition
|com.fca.jira.plugins.workflowToolbox.ExceptUserInCustomFieldCondition
|com.fca.jira.plugins.workflowToolbox.UserInFieldInRolCondition
|com.fca.jira.plugins.workflowToolbox.InitializedCondition|com.fca.jira.plugins.workflowToolbox.ProjectPropertyCondition
|com.fca.jira.plugins.workflowToolbox.AllowedSubtasksCondition
|com.fca.jira.plugins.workflowToolbox.JQLCondition|com.fca.jira.plugins.workflowToolbox.SoftwareTriggeredCondition
|com.fca.jira.plugins.workflowToolbox.BulkOperationCondition
|com.fca.jira.plugins.workflowToolbox.IfMatchesRegexpValidator
|com.fca.jira.plugins.workflowToolbox.AllowedLinksValidator|com.fca.jira.plugins.workflowToolbox.AnyIssueValidator|com.fca.jira.plugins.workflowToolbox.MathExpressionsValidator|com.fca.jira.plugins.workflowToolbox.ParsedTextsValidator|com.fca.jira.plugins.workflowToolbox.UserInFieldInRolValidator|com.fca.jira.plugins.workflowToolbox.InitializedValidator|com.fca.jira.plugins.workflowToolbox.ProjectPropertyValidator|com.fca.jira.plugins.workflowToolbox.AllowedSubtasksValidator|com.fca.jira.plugins.workflowToolbox.JQLValidator|com.fca.jira.plugins.workflowToolbox.CopyParsedTextFunction|com.fca.jira.plugins.workflowToolbox.MathCalculatorFunction|com.fca.jira.plugins.workflowToolbox.ConditionalValueSettingFunction|com.fca.jira.plugins.workflowToolbox.AddOptionToSelectListFunction|com.fca.jira.plugins.workflowToolbox.AddOptionToCascadingSelectFunction|com.fca.jira.plugins.workflowToolbox.FormatTextFunction|com.fca.jira.plugins.workflowToolbox.RegularExpressionRendererFunction|com.fca.jira.plugins.workflowToolbox.CommentAdderFunction|com.fca.jira.plugins.workflowToolbox.AddRemoveWatcherFunction|com.fca.jira.plugins.workflowToolbox.IssueLinkCreatorFunction|com.fca.jira.plugins.workflowToolbox.IssueLinkBreakerFunction|com.fca.jira.plugins.workflowToolbox.WriteLinkedIssuesFunction|com.fca.jira.plugins.workflowToolbox.ReadLinkedIssuesFunction|com.fca.jira.plugins.workflowToolbox.SetUserPropertyFunction|com.fca.jira.plugins.workflowToolbox.ReadUserPropertyFunction|com.fca.jira.plugins.workflowToolbox.ProjectPropertyFunction|com.fca.jira.plugins.workflowToolbox.ReadProjectPropertyFunction|com.fca.jira.plugins.workflowToolbox.WorkLogger|com.fca.jira.plugins.workflowToolbox.AssignToProjectRole|com.fca.jira.plugins.workflowToolbox.WriteIssuesJQL|com.fca.jira.plugins.workflowToolbox.ReadIssuesJQL|com.fca.jira.plugins.workflowToolbox.InhibitEphemeralFieldErasure|com.fca.jira.plugins.workflowToolbox.CloneIssueLinksFunction|com.fca.jira.plugins.workflowToolbox.TextExtractorFunction|com.fca.jira.plugins.workflowToolbox.CopyCascadingSelectToTextFunction|com.fca.jira.plugins.workflowToolbox.SetReporterFromCurrentUserFunction|com.fca.jira.plugins.workflowToolbox.SendEmailFunction|com.fca.jira.plugins.workflowToolbox.CreateIssue|com.fca.jira.plugins.workflowToolbox.CopyToIssueDescriptionFunction
Alvin
June 18, 2019
It works like a charm, validators and postfunctions now appears.  I'll do more couple of test and we'll let you know. Thanks for your help. Really appreciated!
Just want to ask if I can scan all the workflows, not only on a specific workflow. Thank you!
Best Regards,
Alvin
Alvin
June 18, 2019
Aha! I've managed to scan all the workflows by replacing it to this line :
Thank you so much for your help!
Best Regards,
Alvin
Henning Tietgens
June 18, 2019
Oh, you're right. I forgot to remove the workflow restriction in the answer. I corrected the answer. Thanks for the hint!
Henning
Alvin
June 18, 2019
Thank you for this wonderful solution, just want to ask if we can also tweak the script to check plugins that is used in a project, not just on a workflow. Currently , I'm using Power Admin to check it , but its good to have an alternatives. Thank you!
Best Regards,
Alvin
Henning Tietgens
June 24, 2019
Hi Alvin,
I think it's possible to add this functionality to the script, but you may have to do this on your own :-)
Best regards,
Henning
Matt Doar
This one worked like a charm for me, thank you! It's a great example of using an uncommon and. not well-documented Java API for Jira workflows, regex, and an XmlParser. Very useful
Like Henning Tietgens likes this
3 votes
Henning Tietgens
August 21, 2018
here is a refined version of my script.
String searchText = 'customfield'
String result = "Workflow;Function;Type;Action;Source-Step<br>"
if (m.find()) {
wf_flat.each{
def nodeInfo = getNodeInfo(it,searchText)
if (nodeInfo){
result
if (n.name() == 'function') {
def m = n.value() =~ /[^\[{]*/ + search + /[^\]}]*/
if (m) {
nodetext += m[0].toString() + ";"
def p = n.parent()
while (p) {
switch (p.name()) {
case 'validators':
case 'conditions':
case 'action':
valid_action = true
case 'step':
valid_step = true
valid_step = true
valid_step = true
p = p.parent()
return nodetext
} else {
return ""
Dave, please try this.
Henning
David Gordon August 22, 2018
Hi Henning
Many thanks for all your efforts
I'm getting the error shown below
error.PNGThis links https://community.atlassian.com/t5/Jira-questions/Scriptrunner-for-jira-Copy-Project-Error-Timeout-No-stack-trace/qaq-p/209892 says this can be expected and the routune still runs. If so, is there a directory location  ca search for the output?
Regards
Dave
Henning Tietgens
August 22, 2018
In this case you have to replace the line
with
log.error "$workflow_name;$nodeInfo"
Or you can add this line below the above line if you want both outputs. This way the output is in the atlassian-jira.log (you can view the location of the atlassian-jira.log in the 'File Paths' section of the system information page.).
Henning
David Gordon August 24, 2018
Many thanks Henning, that seemed to work
All the best
Dave
Sorry Henning, but it seems to be case sensitive as is correctly matching the lowercase "customfield"  text.
When I try to run for "CustomField" it runs iis a split second and does not produce any output.
Any idea?
Regards
Dave
Henning Tietgens
August 24, 2018
Hi Dave,
Yes, the search is case sensitive. It's searching for workflow postfunctions, conditions and validators from specific plugins by parsing the XML output of the workflow.
If you know what you are searching for and you know a workflow which uses the functionality you can export this workflow as XML and try to find the specific identifier of it. This identifier can than be used in my script to find all workflows using it.
What are you searching for while searching for "CustomField"?
Best regards,
Henning
Hi Henning,
I'm trying to identify all references to a custom fields that use the native number extension (e.g. customFieldManager.getCustomFieldObject(11203L)).
In your script I am using:
String searchText = 'getCustomFieldObject'
but all I'm getting back in a sub-second response In the Results tab is
Because I've have now also searched the XML export with no luck I presume the problem is that the code is references within Post Functions the ScriptRunner workflow function - Custom script post-function (inline script).
Any idea how to search through this?
Regards
Dave
Henning Tietgens
August 26, 2018
Hi Dave, the scriptrunner parameters are base64 encoded since 4.3.3, see https://scriptrunner.adaptavist.com/4.3.3/jira/releases/current-release.html#_base64_encoding_for_workflow_function_arguments. On this page is a link to a script to decode workflow XMLs containing scriptrunner base64 encoded parameters. You could try to incorporate this script into my script to decode all parameters after getting the XML and before searching, between those lines.
Henning
Like Damien Davis likes this
Alvin
June 16, 2019
Good day! Just want to ask why is that only post-function returns onto result tab?
Henning Tietgens
June 16, 2019
Hi Alvin,
It should not. Maybe your search term is to specific?
Henning
Alvin
June 16, 2019
I'm using this:
String searchText = 'com.innovalog.jmwe.jira-misc-workflow-extensions'
and still no validators even if I put one validator just to check. It returns post-functions perfectly but not the validators.
Results:
Sample project - Subtask (Simplified);com.innovalog.jmwe.jira-misc-workflow-extensionsCopyFieldValueFromParent-function;post-function;Create (1);INITIAL
Sample Project - Subtask (Simplified) v1(inactive);com.innovalog.jmwe.jira-misc-workflow-extensionsCopyFieldValueFromParent-function;post-function;Create (1);INITIAL
can you suggest? Thank you!
Henning Tietgens
June 17, 2019
Mmmh. Maybe you could try to export the workflow with the condition as XML and take a look into the xml file to determine which search string should match.
Alvin
June 17, 2019
Thank you for your very quick response, even tho I export the workflow and look for the validator descriptor, it does not display on the script console Results, it just return:
Do we have any other work-around here? Thank you!
Best Regards,
Alvin
Henning Tietgens
June 17, 2019
Could you try my new answer? I hope this helps. Be sure to use the App Key for your app (could be found by expanding the app infos in "Manage Apps").
Best regards,
Henning
Alvin
June 17, 2019
Thank you for keeping an extra eye on this problem, but there is no workflow step returned.
Customfields
Henning Tietgens
June 17, 2019
If you are sure, you use the correct App Key for the script I'm out of ideas. In your first comment you wrote the key for "Jira Misc Workflow Extensions", now it's "Jira Workflow Toolbox", so I'm not sure if everything matches (is the validator from "Jira Workflow Toolbox"?).
Henning
Michael Aglas
I love it - made my day
Ritu Garg April 13, 2021
Thank you. You have written a very useful script.
francis
We are currently using a query on the database, but I'm wondering if there is another approach.
The query is something like
select workflowname
from jira.jiraworkflows
where descriptor like '%iamhuy%'
Hartej Arora May 14, 2021
Hello @Henning Tietgens ,
Just wanted to thank you for sharing this. Worked like a charm for me. I was looking for exactly this that could report on how many of the workflow plugins' modules are being actively used in our instance (without going through each workflow manually).
Thank you!
Henning Tietgens
May 16, 2021
Kiss Zoltán January 4, 2021
Hi!
I know that it's an old topic, but can anyone help in finding only those workflow transitions (workflow name and transition name), where a scriptrunner script has ben used?
Thanks in advance!
Thorsten Letschert [Decadis AG]
Hi @Kiss Zoltán ,
when you're interested in the usage of 3rd party apps within your workflows - in this case ScriptRunner - I'd like to recommend Admin Toolbox for Jira (https://marketplace.atlassian.com/apps/1214246/admin-toolbox-for-jira?hosting=server&tab=overview) and it's built-in workflow report (https://apps.decadis.net/pages/viewpage.action?pageId=13076594) - besides many other useful features for administrators.
Disclaimer: I'm part of the team behind the aforementioned app.
Cheers
Thorsten
David Gordon August 20, 2018
Many thanks Henning
I noticed some warnings as shown below
and when ran it seemed to picked up everything instead of just the lines with 'customfield' listed.
output.PNGAny idea what the problem is?
Regards
Dave
Hi there,
When I run the above code in the ScriptRunner Console I get the following error:
Error
startup failed: Script45.groovy: 13: expecting '}', found '-' @ line 13, column 25. workflows.each{workflow -&gt; ^ 1 error
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script45.groovy: 13: expecting '}', found '-' @ line 13, column 25. workflows.each{workflow -&gt; ^ 1 error
Any idea how to resolve?
Regards
Dave
Henning Tietgens
August 20, 2018
Please try copying the source again. There were some html conversion problems while converting from Atlassian answers to the community site.
Henning
Udo Brand
August 26, 2013
You could export all workflows as xml-files and then search in these files for that plugin (e.g. com.googlecode.jsu). But I guess searching in in the database is faster.
