Sign up Log in
How to find issues assigned to disabled user
Cedric_DEVAUX
A colleague send me a remark around the search issue.
I have a disabled user (he left the company) and I want to list all issues assigned to this user.
If my colleague uses the basic search (screen shot), he doesn't find user
However only if he uses the advanced search and search issues with user account, he finds issues.
I suppose that JIRA is not able to translate user because it's inactive and if we use advanced search,  JIRA search the raw value (firstname.lastname) from the database and give the result.
For your information: we are connected on Active Directory for user management.
Someone could confirm me my theory?
Thank you
2 accepted
Bastiaan Jansen
August 22, 2017
Hi Cedric, I can confirm the theory you shared is correct.
I found a knowledge arcticle about the same topic: https://confluence.atlassian.com/jirakb/search-for-inactive-users-346947771.html
Within this article there is a link to a feature request that has been closed with the JIRA 7.3 fix version: https://jira.atlassian.com/browse/JRASERVER-32874
Bas
Andrew Stanton
I dont know how you can say this is fixed and working when inactive users do not appear in filter selection lists or JQL autocomplete.
Like # people like this
Raul MrAddon
Here an example of Jira JQL function HasInactiveAssignee compatible with Jira 8, the function is in the comments of the post
https://mraddon.blog/2015/08/31/new-jql-function-custom-to-retrive-issues-with-inactive-user-in-assignee-hasinactiveassignee/
Cedric_DEVAUX
Hi Raul,
Thank you for your answer  ;)
15 votes
Chris Bell
Using this JQL statement will display all issues assigned to an inactive user:
assignee in (inactiveUsers())
Devendran Krishnan
June 7, 2022
this solved my problem. thanks
Like 박덕수 likes this
Damian
August 18, 2022
Keep in mind: This is a Scriptrunner-Script. It wont work if you disable the
Scriptrunner App.
Gary Mcdermott December 12, 2022
@Chris Bell  I was hoping you could help with something similar.
An inactive user has left the business, i have followed advanced search and run  the below however it only seems to show me his 'done' tickets, its not showing me any tickets he had in the existing sprint that were under 'to do' I am trying to locate these missing tickets so i can re-assign, thanks
(inactiveUsers())
Igor Silva
This should be the accepted answer.
