×Is there a way to find all issues? I can go in quick search and find one by one but that’s very tedious
How can I find all issues that were moved from project A to project B?
As JQL history search does not support the project field this is not possible out of the box.
You can use Script Runner plugin and the following script to find all issues moved from project AAA to project BBB.
import com.atlassian.jira.bc.issue.search.SearchService import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.Issue import com.atlassian.jira.web.bean.PagerFilter jqlQuery = 'project = BBB' fromProject = 'AAA' result = '' def changeHistoryManager = ComponentAccessor.getChangeHistoryManager() getFilterResult(jqlQuery,log).each{ Issue issue -> oldKeys = changeHistoryManager.getPreviousIssueKeys(issue.id) oldKeys.findAll{it==~/$fromProject.*/}.each{ result += "$it -> ${issue.key}\n" } } return result List<Issue> getFilterResult(String jqlSearch, log) { def searchService = ComponentAccessor.getComponent(SearchService.class); def user = ComponentAccessor.jiraAuthenticationContext.getLoggedInUser() List<Issue> issues = null def parseResult = searchService.parseQuery(user, jqlSearch); if (parseResult.isValid()) { def searchResult = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter()) issues = searchResult.issues } else { log.error("Invalid JQL: " + jqlSearch); } return issues }
Henning
We have jira 4.4.5 running and also using Script runner plugin. Thank you for sharing the script to get the issues that are moved form project AAA to project BBB which is exectly what i am looking for. Appreciate if you could let me know the way to execute this script to get the result.
You have to paste this script to into the script runner console, select Groovy as scripting engine and run the script.
Maybe you have to adapt the script for 4.4.5, I only tested it on 5.1.8.
Will this script impact other data if i execute on production?
It's only reading information. Depending on the number of issues and your system it may decrease the performance of the system for a moment.
Best is, to try it on a test environment first.
is there an Oracle database query that can do the same thing?
Thanks a lot Henning!!! The script works absolutely great! You have just saved my day and most probably plenty of others too...
Kishore Srinivasan
Hi Henning,
Thank you for sharing the script so that more people can benifit out of it.
But unfortunately I am getting below error when i try to run script for my projects
JIRA==> 6.4.13
Adaptavist Script Runner for JIRA Standard Edition==> 3.1.4
Error
startup failed: Script16.groovy: 12: unexpected token: issue @ line 12, column 43. ult(jqlQuery,log).each{ Issue issue -> ^ 1 error
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
^1 error
It would be great if you could provide any guidance related to this
Thanks a lot!
Cheers!
Bhupesh
There seems to be a conversion issue while this answer was transfered to the new community platform. I corrected the script, please try again with the corrected script.
Henning
Perfect!!
Thank you so much!
Now I'll work on adding it for multiple projects and write the output to a file since there is no way to store the results in script console.
Cheers!!
Bhupesh
In the meantime the output format changed to html. I don't know if this was already the case in 6.4... maybe try to replace
with
result += "$it,${issue.key}<br>"
You'll get a comma separated list which could be copied out of the browser.
Henning
Thank you!
We are looking to automate this process like end user should be able to get list of tickets moved from project Ato B and B to A with a button click somewhere in UI in JIRA.
So thinking to put the results in a custom field and put the script in post functions.
Cheers!,
Bhupesh
If you want to use a postfunction you could write the result to the issue as a comment.
if (transientVars.keySet().contains('comment')) {
result+= "\n" + (transientVars.comment as String)
transientVars.comment = result
In this case there should not be any html code in result.
That's really cool.
Can we write it to a custom field? Maybe count of ticket also which moved from A to B and B to A?
You can get the count by using
oldKeys.findAll{it==~/$fromProject.*/}.size()
And of course this could be written to a custom field, see https://developer.atlassian.com/jiradev/jira-platform/guides/issues/guide-performing-issue-operations
@Henning Tietgens Any chance you can help me modify the code above to look at issues moved from any project? Instead of needing an individual Project Key
Sure, you could use this.
def jqlQuery = 'project = BBB'
def result = ''
def issueManager = ComponentAccessor.issueManager
def allOtherKeys = issueManager.getAllIssueKeys(issue.id)?.findAll{it != issue.key}
if (allOtherKeys?.size() > 0) {
// The issue had another key than the current one
result += "${allOtherKeys.join(", ")} -> ${issue.key}<br>"
return result
static List<Issue> getFilterResult(String jqlSearch, log) {
} else {
return issues
You have to adapt the jqlQuery string to select the issues you want to inspect for moved ones.
Henning
@Henning Tietgens This is perfect as to what I need, unfortunately I am getting an error with this snippet
WARN [common.UserScriptEndpoint]: Script console script failed: groovy.lang.MissingPropertyException: No such property: issues for class: com.atlassian.jira.issue.search.SearchResults at Script66.getFilterResult(Script66.groovy:29) at Script66$getFilterResult.callStatic(Unknown Source) at Script66.run(Script66.groovy:11)
I did replace "BBB" with a legitimate project, otherwise I haven't made any modifications. I am on JIRA 8.0.2 (Server Side) and 5.5.3.1-jira8 of ScriptRunner.
I think for Jira 8 you have to replace searchResults.issues by
searchResults.results
Thanks @Henning Tietgens helps to look at the upgrade 8 notes, bad on my part! Ok... one last thing I am struggling with is the log.error(). I'm getting "Cannot find matching method." I see we are passing it, but for whatever reason it doesn't recognize it. If I put log.error above the static line (obviously replacing jqlSearch), it works.
I think this is only an error for the console. If you run the script it shouldn't be a problem. If you want, you could add
import org.apache.log4j.Logger
and define the type for log
static List<Issue> getFilterResult(String jqlSearch, Logger log) {
to get rid of the error in the console.
Thank you.... I had tried the import and even tried defining the type... I erroneously defined it as "Log log" and not "Logger log". Ugh. Thank you so much for your quick response! I think we are sailing now!
Thanks, @Henning Tietgens for this wonderful script. Is there a way to get a date along with the ticket number when it is moved from project A to Project B.
Yes, you have to analyze the change history items for each issue found (ComponentAccessor.changeHistoryManager.getAllChangeItems(issue)) to find the change of the issue key. From this change you can get the date (changeItem.created).
Thanks @Henning Tietgens for your response. I am not a coder - so could you please help me how to append these parameters within your script.
I will appreciate your help.
I don't think it's a good idea to use these scripts without any knowledge of what's going on.
Just try it, it's not that difficult. Try to get something working in Groovy and come back with specific questions.
Or hire somebody to code and maintain these scripts for you.
All these scripts have to be maintained, especially for Jira upgrades, they have to be tested and updated because of API changes.
Don't understand me wrong, I like to help, but not for "Please code for me" questions.
Correctly said. Thanks.
If the initial and destination projects use different sets of status' then one can figure what moved from project A to Project B.
E.g. if project A always uses a status = review before the issue is moved to project B, where "review" status is not used, then the following query will find all the issues in project B that have project A pedigree.
project = B and status was in (review)
This will not find issues that were created in Project B (and not moved from Project A).
Could you please explain the project declaration?
For example: "jqlQuery = 'project = BBB'
fromProject = 'AAA'
result = ''
What is the 'project = BBB' fromProject = 'AAA'? Is It project ID or project name?
jqlQuery is a query like you would enter in issue search in advanced mode. This could be project = <PROJECT KEY> or <PROJECT ID> or <PROJECT NAME>. This query should find all issues where you want to know which are moved from "fromPrjoect".
fromProject is a project key (technically it's the start of the issue key). This is the previous project of the issues.
Best regards,
Henning
I see this issue is very old. Has JQL been updated to be able to handle cases like this? We are on the cloud version and do not have script runner.
I am also interested in learning about how we can query for issues that have moved from one project to another and I don't have a script runner.
The JQL Tricks Plugin seems to have a function to return moved tickets.
Hi, this is a fantastic thread!
When I try to run this script with the modification I get an error - how can I fix that (see below). And an additional question - how can I change the script to show issues which were moved from one ticket type to another within the same project?
def result = ''
return result
issues = searchResults.results
} else {
return issues
Error
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script90.groovy: 29: Apparent variable 'searchResults' was found in a static scope but doesn't refer to a local variable, static field or class. Possible causes: You attempted to reference a variable in the binding or an instance variable from a static context. You misspelled a classname or statically imported field. Please check the spelling. You attempted to use a method 'searchResults' but left out brackets in a place not allowed by the grammar. @ line 29, column 18. issues = searchResults.results ^ 1 error </pre>.
Hi, there is one s to much on the end of searchResult. Without it the code should be ok.
For issue type changes you have to analyze the issue history (change items) like for the change date above.
Best regards,
Henning
Hi Henning,
Its working fine if there are few number of issues are moved from the project.
But I'm getting an error while checking more issues those are moved from one project to another project . "Error timeout : No Stack Trace available."
Any way to fixed this issue ?
Sushanta
Hi Sushanta,
in this case you have to replace the "result +=" with "log.error " to write the output to the atalassian-jira.log file. This will continue, even if the UI reports a timeout. Additionally I would add a line "log.error "Done." before the line "return result", to see in the log file when the script is done.
Henning
Yes, you will get the timeout error, but the script will continue to run in background. Because in this case you don't see the result of the script, the result should be printed to the atlassian-jira.log file.
log.error "$it -> ${issue.key}" } }
log.error "Done."
return result
You can view the location of the atlassian-jira.log in the 'File Paths' section of the Jira system information page.
Henning
Hi Henning,
Thanks for your quick response.The work around is working fine. Now I'm able to see the results in catalina.out .
Sushanta
How would I filter my results by last 30 days?
What last 30 days? Created?
You can modify the JQL like : jqlQuery = 'project=XXX and issuetype=XXX AND created >= 2018-10-01 AND created <= 2018-10-31'
We tried Postman, and were able to pull the raw data.
However, the challenge we came across is the following:
Say issue AAA-123 is moved from project AAA to project BBB, and the new issue # is BBB-345;
We are not able to pull any historical data from project AAA for the issue AAA-123; we have to pull data from project BBB. For the issue BBB-345, we can see that it was moved from project AAA, and the id was AAA-123.
Is there a was for us to pull the move related from AAA ?
Thank you,
Veeraj
