Hello, is there a way to find all the issue types that are not used in any project for the whole instance? A rest API, or sql query will do, tried several options but nothing really helped.
Trying to clean up out Jira DC instance without any plug-ins.
Hi @Valentina C Welcome to Atlassian Community!
If you have a scriptrunner plugin, Kindly try to run following script in Script Console to get issue type issues count :
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface) ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default")
def sqlStmt = """
select
it.id as "Issue Type ID",
it.pname as "Issue Type",
count(ji.issuetype) as "Number of Issues"
from
issuetype it
left outer join
jiraissue ji
on
it.id=ji.issuetype group by it.id
order by count(ji.issuetype) asc ;
Connection conn = ConnectionFactory.getConnection(helperName)
Sql sql = new Sql(conn)
String result = """
<table>
<tr>
<th>Issue Type ID</th>
<th>Issue Type Name</th>
<th>Issue Count</th>
</tr>
sql.eachRow(sqlStmt){ it ->
result += """
<tr>
<td>${it.getAt("Issue Type ID")}</td>
<td>${it.getAt("Issue Type")}</td>
<td>${it.getAt("Number of Issues")}</td>
</tr>
return result+"</table>"
sql.close()
SQL Query :
select
from
issuetype it
left outer join
jiraissue ji
on
Hey @Vikrant Yadav !
We do not have script runner but I ran this SQL query and it worked!
I just added it.pname to the group by clause like this
select
from
issuetype it
left outer join
jiraissue ji
on
it.id=ji.issuetype group by it.id, it.pname
Thank you very much!
Hi alltogether!
We faced a similar issue and this SQL worked like a charm, thank you very much!
To be sure: It just only returns active issues? So archived issues are not counted, are they?
Thank you very much in advance! :)
Hi @Valentina C ,
Please refer below link to find un used issue types. I hope this helps you
https://confluence.atlassian.com/jirakb/how-to-find-unused-issue-types-with-sql-1072216995.html
Tried it already, but it's not retrieving any results unfortunately
May be there are no used issue types.
Please try the first query by replacing NOT IN with IN and check whether you are getting all issue types or not.
it's giving info without NOT but not the result I need whatsoever, thank you, the below answer worked for me
Save your spot
