I am getting a number of warning
/opt/atlassian/data/jira/log/atlassian-jira.log:2018-11-06 10:32:14,374 http-nio-9000-exec-11 WARN user 632x269792x2 um8gea IP,IP /secure/CommentAssignIssue!default.jspa [c.a.j.w.action.issue.CommentAssignIssue] The i18n keysd.workflow.itsupport.v2.transition.respond.to.support.description in property 'jira.i18n.description' for this transition does not contain a valid i18n key.
Unable to see in the UI any property called jira.i18n.description. There were two others jira.i18n.title and jira.i18n.submit
After exporting the workflow I was able to see clearly where that warning line was reading from (refer to the 3rd meta tag);
<action id="781" name="Ready for Support" view="fieldscreen">
<meta name="jira.i18n.submit">sd.workflow.itsupport.v2.transition.respond.to.support.submit</meta>
<meta name="jira.description"></meta>
<meta name="jira.i18n.description">sd.workflow.itsupport.v2.transition.respond.to.support.description</meta>
<meta name="jira.i18n.title">sd.workflow.itsupport.v2.transition.respond.to.support.title</meta>
<meta name="jira.fieldscreen.id">12633</meta>
<results>
<unconditional-result old-status="Not Done" status="Done" step="8">
<post-functions>
<function type="class">
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowupdateissuestatus-function</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.UpdateIssueStatusFunction</arg>
</function>
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowcreatecomment-function</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.misc.CreateCommentFunction</arg>
</function>
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowgeneratechangehistory-function</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.GenerateChangeHistoryFunction</arg>
</function>
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowreindexissue-function</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.IssueReindexFunction</arg>
</function>
<arg name="eventTypeId">13</arg>
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowfireevent-function</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.event.FireIssueEventFunction</arg>
</function>
</post-functions>
</unconditional-result>
</results>
</action>
I don't see the action
... am I looking in the wrong place?
Finally, how do I get that property to 'contain' a valid i18n key?
