×Community moderators have prevented the ability to post new answers.
Hi @Natalia Ávila ,
Have you checked if it's any of the bugs linked by Angelica? Otherwise please create a new thread for your issue:
- Images fail to load in the new issue view when creating linked issues
- When pasting a text with images as a comment on the new issue view the attachments fail to load and the comment can't be added
- Cloned tickets that have images on description shows "Failed to load" when using the new issue view
- Attachments break when editing the description in the new Jira issue view.
If none of the bugs mentions the same behavior you are facing, I'd suggest you create a new question in community, so we can treat each case separately.
In case it is one of above bugs, please vote for it and set yourself as a watcher so that you will be notified in case of any update/progress. The bugs will be addressed according to the Atlassian Cloud bug fixing policy.
Dario
Same issue here. Or two of them, as for some issues old view helps (although super tedious to change every time), and for some it doesn't.
Same here - we work a lot with Confluence and experience the same issue - it is very risky to put there a lot of work and lose it all
I am experiencing the very same issue. Seems to be related to large attachments. If I replace with smaller image works just fine. Please suggest a solution.
still have this issue - My files average 120kb - png exports from Figma, etc.
I have this regularly on both Confluence and Jira.
I am losing time on this and have to do double the work.
For me, the problem also occurs with very small images. It's intermittent. If I try a few times it eventually works. This and the "jwt expired" error I mentioned above seem to suggest something is failing temporarily.
Hello, we are stuck in the middle of our migration to Jira Cloud with none of our attachments showing up. Our storage size suggests that the attachements are there and we followed the folder structure in the instrustions "attachments.zip -> data-> attachments-> projects etc.
Thank you,
Hi @Joost_Boer
check the logs for the specific error and post here.
Errors I’ve experienced with attachments are:
>configured max file size 10mb
disk permissions changed
disk full
Thanks Tom.
The problem somehow seems to gotten resolved by itself.
Same problem here, have this error:
OPTIONS https://api.media.atlassian.com/items net::ERR_NAME_NOT_RESOLVED
This is somehow related to domains records.
