×The URL encoding of web links for Git Repositories in Jira is different from the URL encoding used by Fisheye. As a result, the links to the modified files for a ticket that are listed under the "Git Commits" tab are broken.
For instance, if I have a repository MyGitProject with a path 'c++/someFile.cpp', the URL in Jira will be:
http://fisheye-server:8060/browse/MyGitProject/c++/someFile.cpp#841e1caa1ce
But the correct URL for fisheye should be:
http://fisheye-server:8060/browse/MyGitProject/c%2B%2B/someFile.cpp#841e1caa1ce
(fisheye encodes the 'c++' part of the URL, that becomes 'c%2B%2B')
My guess is that I would need to replace the '${path}' in the "File Modified Format" with somethin like '${urlEncodedPath}' in the 'web linking' section of the repository, but I couldn't find the relevant variable (or even the relevant part of the documents)
Thanks for any help
This is a known bug in the Jira FishEye Plugin , see https://studio.plugins.atlassian.com/browse/FISH-453
